Couple OC questions
Old May 10, 2012 | 05:16 PM
Darkstar752's Avatar
Couple OC questions
Hi guys, couple quick ?'s
I'm looking at a G35 coupe, 59,000 miles and the only problem is it burns oil, 1 quart every 4000 miles.
- How severe is this?
- Will a catch can help?
- Does the problem worsen over time?
- How does it affect the engine?
Thanks guys, not all answers are needed I just need some quick answers as I wanted to check the car out on Saturday.
Old May 10, 2012 | 07:45 PM
superchargedg's Avatar
1 Qt every 4000 miles is pretty much normal with a lot of engines.
Old May 10, 2012 | 09:57 PM
a471133's Avatar
^ second that , mine consumes that much as well. A catch can won't really affect how much oil comes out of your engine, it will just give you a way to gauge some of the oil that is lost as well as keeping the oil from ending back up in your intake/plenum. End result is you are still -1qt motor oil in the end.
Old May 11, 2012 | 08:02 PM
westbank23's Avatar
Your good.mines consumes a quart ever 2000 miles lol
Old May 12, 2012 | 12:39 AM
gary c's Avatar
A quart every 4K miles isn't bad but it may not get any better. Are you using 5W/30 like the manual recommends? You might try 10W/40 and see how that effects your consumption. Catch can won't make any difference with your issue, but they are good for your VQ motor. One as simple as the Home Depot can (Search) is worth the $$. Using 1 qt every 4K miles won't effect your engine, just watch it closely....Gary
Old May 12, 2012 | 01:23 AM
atonal's Avatar
would the type of oil make a difference? do you guys prefer the 5w/30 or synthetic?
Old May 12, 2012 | 08:59 AM
gary c's Avatar
Most of us use synthetic but having OC issues isn't the time to be switching brands or types. Doing so might increase the OC and the only thing I'd change w/b the weight from the 5W30 to 10W40 which might help. Some dealership might even tell him 1qt in 4K miles is normal....Gary
Kng0fHrts
Sep 15, 2015 05:40 PM
baker2795
Sep 2, 2015 06:00 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlackGee35
Jul 21, 2015 07:24 PM
