wheel spacer help please!!
i need some help on wheel spacers i got 19in rays dropped about 1.5 all around . I want some spacers that will make sure the orignal studs are tucked in enough so i dont have to cut or get shorter 1's ran into this problem on a 370z also were i dont have to pull the fenders either thnx .
it puts more stress on your hub bearings. but not to the point to where you are going to have to worry about it really. also just installed 25mm on the rear of my g coupe, dropped on s-tech w/ cut spring mount. i did go ahead and roll my fenders cause i plan on going lower in future. you will prolly get away without rolling yours, as long as you don't go over 25mm and don't pack down the rear end
Sorry to thread jack but since were on the topic of spacers. I have a set of 370z sport wheels with 25mm spacers in the front and none in the back. Is there anything wrong that I'm sitting. +22 in the front and +30 in the rear?
