DIY: TPMS sensor reset
Hmm. Would this fix my issue where my light comes on after 30 miles at freeway speed, even though all tires are in pressure spec (can restart car and get another 30 miles no problem)? Incredibly consistent, independent of outside temperatures.
Would hope not, brand new TPMS when I got the wheels from TireRack. Guess I'll give them a call.
Where can I find said sensor on the wheel? I know they look vaguely like a drum key (a "T" with a really fat top), but I thought they are inside the tire?
I'm guessing it's a temperature related issue, as sustained 60mph+ is going to raise tire pressure one or two PSI. Apparently the sensor doesn't like that.
There isn't a specific wire, it's all on the car network CANBUS, the BCM reads the signal and turns the light on via CANBUS to the dash if it doesn't have the correct data
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
