Overheating
Old May 25, 2012 | 05:58 PM
mcw0323's Avatar
Engine running....no bubbles in reservoir tank.....
Old May 25, 2012 | 06:08 PM
xXHotelCrazyXx's Avatar
Typically if there are bubbles in the reservoir, then you know its your head gasket, and since you dont have white smoke coming out of the tail pipe, i say continue to bleed the system while making sure the radiator is full.
Old May 25, 2012 | 10:53 PM
mcw0323's Avatar
Still no luck....so I'm clueless... :-/
Old May 25, 2012 | 11:30 PM
Is there still air coming out...it;s possible your mechanic put the thermostat in backwards, but i doubt it. If you said your heating got better after the bleed then there is definatly air in the system...did you have a friend hold the rpm to 3k after it warmed up and crack the bleeder screw for a bit until a solid flow of coolant came out?
Old May 26, 2012 | 12:21 AM
gary c's Avatar
I won't ask why you didn't take your G back to the guys that installed your new radiator and thermostat like I suggested....seems like it was there problem doing the job wrong.
Gary
Old May 28, 2012 | 02:50 AM
Ye_Budyy's Avatar
first off i wanna say that sucks so bad...this reminds of back when i had my STI...got rid of it because of the overheating issue...spent hundreds trying to change everything but ended up being the head gasket...
but heres another way to check if you have a head gasket problem....take the radiator cap off and leave it off...then start the car....if water shoots up out of the radiator its not a good sign
Old May 28, 2012 | 01:07 PM
mcw0323's Avatar
Found out it is head gasket.....radiator place ran some kind of test and it showed positived....any ideas on how much it's going to cost overall for this..
Old May 29, 2012 | 11:13 AM
LoSt180's Avatar
If the radiator place couldn't properly bleed your system in the first place, imagine what they can screw up replacing a head gasket... Just saying, get a second opinion.
G35Rican
Jul 31, 2024 01:37 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
