Overheating
Old May 25, 2012 | 12:42 PM
mcw0323's Avatar
Overheating
Got an 05 G35 coupe.....had overheating problems, had a new radiator and thermostat put in....no coolant is leaking out and water pump is properly circulating the coolant.....car is still overheating....when sitting and idling it doesn't overheat, but as soon as I move 100ft the temp starts to rise....heat also does not blow out hot air, just cool/warmish air...don't know if that's relevant to my main problem but....any ideas or help is needed....! Need any more info on car or what's going on ask...!
Old May 25, 2012 | 01:35 PM
gary c's Avatar
Obvious answer, take it back to where you had the radiator installed! As long as the fluid is moving and your fans are coming on it's probably an air bubble....Gary
Old May 25, 2012 | 02:01 PM
xXHotelCrazyXx's Avatar
The car will overheat if you do not bleed the air out of the system properly from the bleeder screw on the aft passenger side of the engine
Old May 25, 2012 | 02:04 PM
http://www.youtube.com/watch?feature...v=WP2FUiP4bYg#!
Old May 25, 2012 | 02:21 PM
mcw0323's Avatar
Watched the video already and bled the system accordingly.....it doesnt make any sense....still overheating...
Old May 25, 2012 | 02:22 PM
(With the engine warmed up) have a friend run the engine up to 3k RPM and hold it there, and crack the bleeder screw open for about 5-10 seconds
Old May 25, 2012 | 02:30 PM
mcw0323's Avatar
Just tried to bleed the system again....and it had an awful lot of air in it......hmmm
Old May 25, 2012 | 02:32 PM
Well that is your problem
Old May 25, 2012 | 02:35 PM
mcw0323's Avatar
How many times does this have to be done? On a normal scale...
Old May 25, 2012 | 02:36 PM
Just once when done right, and make sure your radiator is topped off...
Old May 25, 2012 | 04:29 PM
mcw0323's Avatar
No luck......what would the next task to take.....seems like its just full of air?? Head gasket leak?
Old May 25, 2012 | 04:36 PM
mcw0323's Avatar
Now the heater is heating properly.......and something else odd to me...after it gets hot, as soon as I turn the car off, about one minute if that, it goes back to the normal temp...and also the reservoir is filling up and overflowing when the car is on...I'm stumped.
Old May 25, 2012 | 05:22 PM
Do you have white smoke coming out of the taip pipe?
Old May 25, 2012 | 05:44 PM
mcw0323's Avatar
No smoke at all......my last resort I guess is head gasket?
Old May 25, 2012 | 05:46 PM
With the engine running take the cap off your reservoir and see if there are bubbles in there with the hose still down in the coolant
