g35 rear diff vs g37 rear diff
Old Sep 30, 2015 | 07:46 PM
  #31
Dannyy06's Avatar
I did check the oil and its ok to the level.. I dont dare to drive it much but when i took it to the mechanic he lift it got under and told me that it was coming from the diferrential. That it could be a bearing but to rebuild it it will cost more than to buy a used one..thats why i want to know if one from a G37 can fit my G35 or if i have to buy an exact one!!
Old Oct 1, 2015 | 09:37 AM
  #32
LoSt180's Avatar
You would need one from an 07 - 08 Sedan with AUTO trans. 09+ G37 diffs will physically fit, but the final drive ratio changed when the 7AT came out, so your car would feel a little sluggish. G37s with 6MT have the proper drive ratio, but the front flange is different. Not sure how easy it is to swap out though.
Old Oct 1, 2015 | 10:14 AM
  #33
Dannyy06's Avatar
That limit my search!!! So i need to figure out if i can use my flange with another differential if i found a g37s .. Ok thanks let me know if there is other solution!!
Old Sep 5, 2016 | 12:52 AM
  #34
Jimster480's Avatar
Does anyone know if the 04 AT Diff is the same size as the 04 MT diff?
I was reading about the Diff swap and I have a 04 AT w/ VLSD and I see a 04 MT VLSD for sale on ebay but I don't see any difference.
Are they the same in the 03/04 model year or possibly the 03-06 model year?
Because the 07+ ones are clearly different between manual and automatic.
Old Sep 5, 2016 | 12:16 PM
  #35
partyman66's Avatar
They have different final drive ratios. If you put in a 6MT rear end you'll spin higher RPMS on the highway and have slightly reduced fuel economy but better acceleration. Your speedometer will also be off by a bit assuming you keep stock sized outside diameter on your rear tires.
If you're ok with those things... I think you can just swap in the other diff.
Old Sep 5, 2016 | 01:19 PM
  #36
Jimster480's Avatar
I know about gear ratios.... And I know that the manual diff will fit.
Also the speedo shouldn't be off.
What I am asking is if the Differentials are physically the same other than the final drive gear, because I am going to do a 3.961 FD upgrade.
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
