Stressing in need of help....
Old Jun 2, 2012 | 10:00 PM
Konla0916's Avatar
Hello everyone,I need vent and get some advices from you all. My uncle passed away on memorial day...we are close him and I...anyways his funeral is next week in San Jose which is an hour and 45min drive from where I am. Today as I was driving my 06 g35 6MT my SES came on throwing a code p1084. Now I've seen a couple post with that code on this forum but there wern't any solution really...more of a "luck" type of thing that fixed the problem. So the code stated its Exhaustt Valve Timing Voltage CIRCUIT BANK 2. So today luckily enough I found a shop that is open on the weekend and got my camshaft positioning sensor changed on the driver side. As I drove it for about 2-3 hours the SES light came back on but even before when it was still off for that 2-3 hours my car still felt like it had no power and it idle at about 1000 - 1100 RPM which is a tad bit high. So i tried calling the shop back but they have closed for the day. This is going to make me not want to sleep tonight and I will be thinking about it ALL night so i figure some of you can shed some light on me while I wait a few days to take my car in to the mechanic. Thank you..
Old Jun 3, 2012 | 01:13 AM
XternaL's Avatar
sorry to hear......i've heard the crankshaft sensor can also cause the problem? That's the only thing i can think of hopefully someone here on the forum can help you.
Old Jun 3, 2012 | 01:41 AM
blaccG35's Avatar
sorry for your lost buds...maybe you just need to reset your ecu after the install?
Old Jun 3, 2012 | 01:44 AM
Konla0916's Avatar
Thank you both.....hrmm im not too sure if the mechanic reset the ecu or not...but lf i install the sensor and don't reset the ecu it can still cause my car to lose power and idle high?
Old Jun 3, 2012 | 04:38 AM
kristinavq's Avatar
do the foot peddle reset or disconnect your battery for a hour or so .. i had the same issue but mine didnt lose power or idle high
Old Jun 3, 2012 | 04:55 AM
blaccG35's Avatar
im not to sure bout that...but it wudnt hurt to try...GL
Old Jun 3, 2012 | 12:00 PM
Konla0916's Avatar
I did the ecu reset and about 5-10 miles the light came back on. If the new sensors aren't bad what else can it be?
KevinnnVo
Oct 14, 2024 04:33 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Usman Ali
Sep 22, 2015 06:59 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
