Problem after installing test pipes
Old Jun 14, 2012 | 02:54 PM
tylerxfire's Avatar
i can assure u that this is not normal for the guy saying this is..i have used numerous different high flow cats and test pipes with aftermarket exausts and stock exhaust and never had a rattle sound..u must have something rattling around on decel..get under and shake the **** out of the test pipes and the rest of the exhaust and duplicate it and track it down...rasp is one thing..something banging metal to metal is not normal
Old Jun 14, 2012 | 03:22 PM
dofu's Avatar
20 Year Member
Like others have said, the rattling is probably the heat shield or rasp if you're not used to hearing it. If you have a stock exhaust (or even aftermarket, I guess), it could be a muffler width piece that looks triangular from the side that's there purely for aerodynamic purposes. That thing comes loose and rattles a lot.
As for the CEL, you just need a non-fouler. You can get a mechanical one that just raises the sensor away from the piping, or you can get an electronic one. They both do the same thing, and they both work great. Only the electronic one, well, it's electronic so it can and will eventually burn out.
Old Jun 14, 2012 | 04:14 PM
Mr. Brett's Avatar
OP, does the noise sound like this?
First heard at 0:33 in.
http://youtu.be/Qxn2_54EXDQ
Edit:
Blah. I forgot how to embed videos on GDriver. I'm used to doing it on another forum.
Old Jul 13, 2012 | 04:37 AM
bchalks's Avatar
Edit:
Does anyone know how to get rid of this noise? Would a 2.5in Y-pipe solve the problem? Or is it the headers?
Old Jul 13, 2012 | 12:33 PM
Mr. Brett's Avatar
I've heard the noise will be reduced if you get a Y-pipe. Not sure about the headers.
I think the sound is kind of amusing. I've had a few ricer kids ask if it was my "blow off valve."
Old Jul 13, 2012 | 11:34 PM
bchalks's Avatar
No doubt it's amusing to hear what other people think it is. In fact, my ricer friend asked me if it was my wastegate....
Anyway, I think I'm going to get a y pipe to try and get rid of it. Anyone recommend the Megan y pipe?
Old Jul 14, 2012 | 01:18 PM
Mr. Brett's Avatar
Megan's test pipes are decent. I don't know about the quality of the y-pipe. A piece that big, I'd suggest Motordyne or another company that uses quality parts.
Things like test pipes are a dime a dozen, and aren't expensive to replace if they rust through. Y-pipe is a bit of a different story.
Old Mar 17, 2025 | 08:18 PM
Usernameavaible's Avatar
G37x Base
TP rasp
Originally Posted by midnighttheg35
I just installed top speed resonated test pipes on my 06 6mt coupe. After installing them, my cel light came on (to be expected) but i also get a weird rattling sound while driving. It happens between 2 and 3k rpm and only when im fully off the gas. While its happening, if i press on the gas a little, or if i go into neutral, it goes away. It sounds like a high pitched rattling.
I dont know if this has anything to do with it, but the metal
Brace that bolts to the cats is not in as the top speed pipes didnt have brackets on them.
Any ideas?
Thanks
so what was the answer, I have the same issue but already tackled and tested all of the mentions. No shield, no bolts, no nothing but a mystery rattle and a constantly leaking flange between TP and manifold .. Seems to be the manifold.
I was even gona change the stock resos.
I have a 2.5" Y pipe with the TP, and ultra quiet resos for mufflers. Rest is stock.
the rattle is still there, I even heat wrapped it, helped abit with the rattle...
can never figure it out 😭
Old Mar 17, 2025 | 08:55 PM
thisiswang's Avatar
sorry but the answer is that its a cheap test pipe and the rattling is coming from the material inside the resonated portion
Old Mar 17, 2025 | 10:33 PM
G37x Base
Sorry but that's not the answer.. I don't have resonated test pipes. I also have the flex joint str8 piped and it's 2.5"
The test pipes are from z1 they are said to fit on stock exhaust so apparently that's bogus.
But they should be good quality...
Are you telling me that it's z1 TP that make that rattle on decel?
I hope someone else can chime in because frankly I don't think you have the answer..
Old May 18, 2025 | 01:50 AM
Gino Bogers's Avatar
Ivory Pearl, TS-1 C/F SEIBON hood, TS-1 C/F fr.bumper, VS-4 c/f fr.fnders, OE Gialla trunk spoiler
06 G-35 MT-6 Sport Coupé VVT REVup
Any ideas?
Thanks
So I had Nismo headers installed with 1320preformance open Test pipes ( resin free cats)and am running a true duel exhaust ending in the back HKS rear tuned exhaust NOW, For one check engine Light is get yourself (4) 90° O2 extenders/adaptors 2 up stream and 2 down stream and (SHOULD) eliminate CEL coming on. Now your noise in a manual MT-6 when changing out factory cats BETWEEN the.L & R side you have a metal (boomeroang) looking bracket that secures the OEM exhaust Cats, which are useless when running, HEADERS, TRUE DUALS TO TAIL PIPES,
so under accelerator heavy, light or a torqued turn L or R you have a slight exhaust hit at a certain point. It'll take a while. Look for a raw.mettal.thats been touching and when locate it install fire proof padding thick enough that it wont fall out and eventually will wear away and.then just repeat again. No big deal. Just play with your girl and youll find out all about her little finicky quirks and like a real woman find out her.issues and try to prevent any future complaints.🤪
chinee
Jun 10, 2024 07:48 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
andresito7
Aug 1, 2015 04:53 AM
