Need Help With Bushing on bottom of rear shock!!! Knuckle Bushing?
Old Jun 4, 2012 | 09:07 AM
ryan.zipkas's Avatar
Hey, this is my first post on here because I'm in a little bit of a jam. I was replacing my rear shocks this weekend and when i got to my drivers side rear, the bushings where the shock bolts to on the bottom were given me trouble. I took it to my local shop and he said that the bushing is jacked inside the knuckle, and that if i get luck i may be able to find one. Does any one know where to order one? I've looked through posts before and followed all the links, but it seems that every bushing is for the other part of the knuckle. Im not even sure if the knuckle is the correct part, but any help would be appriciated. I don't want to replace the entire knuckle since that is a lot of money, and would love if i could get away with just replacing the bushing. thanks in advance
Old Jun 25, 2012 | 11:22 PM
Theory_EK's Avatar
Since you going to replace it anyways and having it pressed out you could always go with poly bushings from energy. I am in the same spot as you and thats the route I am going.
Old Jun 25, 2012 | 11:27 PM
Well I orders some performance bushings,the problem I'm having is trying to find someone to install them..Infiniti dealership thinks I'm speaking Greek and giving me insane estimates.
Old Jun 26, 2012 | 08:15 AM
fatlip's Avatar
Any performance shop or machine shop canwdo it. Wont be expensive if u bring the control arms to them.
Old Jun 26, 2012 | 11:25 AM
Theory_EK's Avatar
Yeah you can take the arms off you self and take them to Napa.
Old Aug 19, 2012 | 12:42 AM
PAIXAO's Avatar
I'm going to bump this up rather than create another thread for it. Was installing my coilovers today when I came across somewhat of the same problem but my bolt was seized to the bushing. The only way for me to get the rear shock off was to cut it with a reciprocating saw.
Can anyone tell me what this bushing is called.so I can get another one and press it in?
Thanks.
Old Aug 19, 2012 | 12:41 PM
So after i posted this i did get it fixed, however i could not find oem bushings, just aftermarket...heres the link
http://www.z1motorsports.com/product...oducts_id=5893
Old Aug 19, 2012 | 12:48 PM
yup i gave you the wrong link..thats for the 300zx...but i found them on that site by searching for rear shock mount bushing...sorry but thats the best i got till i can track down my order form
Old Aug 19, 2012 | 04:43 PM
PAIXAO's Avatar
I ordered the whiteline bushings from B2Autodesigns. Part number WLW62535 in case anyone else comes across this issue. Now all I need is a press lol.
rezendvous420
May 31, 2020 01:26 PM
R350k5
Oct 1, 2015 08:41 PM
si_driver
Aug 11, 2015 07:08 AM
teamghost
Jul 28, 2015 04:52 PM
itschuckster
Jul 25, 2015 08:07 AM
