Question about clutch
Old Jun 20, 2012 | 09:01 PM
S_johnston69's Avatar
Hey all sorry if this has already been posted but i tried looking and didn't see anything. But I have an 07 6MT Coupe and today i was driving and at first like usual i barley had to push in the clutch for it to engage to shift but toward the end of my 35 minute drive home from work i was having to push my clutch in pretty far for it to engage.So when i got home i sat in neutral and pressed on the clutch to see how far i had to push the clutch in for it to go into first and it was really close to the floor..so what is wrong?
Old Jun 20, 2012 | 09:30 PM
partyman66's Avatar
Have you ever changed the fluid for your hydraulic clutch? Did you recently have any work done on the car? If so... it's possible that whoever worked on the car may have introduced air into your clutch hydraulics.
A simple hydraulic clutch bleed and fluid replacement may help you out.
Old Jun 20, 2012 | 09:49 PM
I just had a new clutch and flywheel put in a fresh fluids 3000 Miles ago and it did it before then too
Old Jun 20, 2012 | 10:41 PM
Texasscout's Avatar
Most likely you have air in the system. You need to flush the master and slave cylinders.
Check you fluid level first
jsimonk
Dec 22, 2023 03:49 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
