camber help !!!
Old Jun 29, 2012 | 02:57 AM
kristinavq's Avatar
camber help !!!
so i thought i fixed this along time ago !! i listened to every one and got a spc camber kit for the rear on dropped on eibach spring 1.2in all around i keep getting camber wear i did my aligment like 3months ago !! Should i redo it ?? or add spacer or something ?? lol any help
Old Jun 29, 2012 | 04:17 AM
kristinavq's Avatar
also my last specs were 0 camber and 0 toe the front has 1.8 and 0 toe and theres no wear there
Old Jun 29, 2012 | 04:23 AM
DrewDrew's Avatar
Odd. It's def only camber wear. Out of wack toe would eat your entire tire as well - but I see plenty of tread left across the tire.
I would go back to your alignment place. Show them you got an alignment X amount of time ago, explain that you have negative camber wear and would like them to double check their readings. If they refuse or something doesn't seem right, find a more reputable place.
Only thing I could see happening would be that your camber arm nuts have slipped.
After all that, it could be that you just have bad suspension parts - shocks, bushings (not really a problem in the rear), tie rods, etc. Have them check everything over for wear when you drop by.
Old Jun 29, 2012 | 03:06 PM
VMRWheels's Avatar
OP - Do you have any additional photos of the tire you posted?
Old Jun 29, 2012 | 05:18 PM
tylerxfire's Avatar
im on sportlines with spc rear camber kit (adjustable arms and toe bolts) i was aligned about 3 months ago and have zero wear..id say bring it back and get a real alignment or somewhere else
Old Jun 29, 2012 | 08:14 PM
kristinavq's Avatar
heres another pic
Old Jun 29, 2012 | 08:48 PM
soundmike's Avatar
Hard to tell from the pics, but from what i can see you have exaggerated toe related wear. Camber wear would be more gradual from inner shoulder to roughly mid-tread. It seems uniform to me except for that narrow spot on the shoulder.
Old Jun 29, 2012 | 08:51 PM
4DGS's Avatar
Rear end bounce at all? Struts could be blown.
Old Jun 29, 2012 | 09:16 PM
VMRWheels's Avatar
Looks like toe wear to me to be honest.
Old Jun 30, 2012 | 02:08 AM
kristinavq's Avatar
Alright ima take it baq to the shop then and shocks are only 3months old
Old Jul 3, 2012 | 01:38 PM
kristinavq's Avatar
so i went and got an aligment today im pissed they couldnt get the rear in spec with the spc camber kit some older guy who never heard of these kits and they refuse to give me a refund i got it in spec before !!!
Old Jul 3, 2012 | 01:43 PM
CLEANBS's Avatar
the front is good
but the rear alignment is horrible
take it somewhere else asap they obviously have no clue, those rear specs are a joke
Old Jul 3, 2012 | 01:46 PM
VMRWheels's Avatar
Try another alignment shop. Don't know why they'd be telling you that though...
Old Jul 3, 2012 | 04:26 PM
kristinavq's Avatar
The shop said its maxed out is this possible?
kristinavq's Avatar
The rear
