So which Oil Is Best??
Old Jul 15, 2012 | 09:50 PM
  #31
OldManRivers's Avatar
I use royal purple.... of you look at those numbers, they used royal purple 5w-30 vs amsoil 0w.... I have used RP for a long time in all my motors and they all have been amazingly clean... Nuff said
Old Jul 15, 2012 | 10:47 PM
  #32
PAIXAO's Avatar
The best oil is subjective. I put nothing but high quality synthetic oil in my G35 from day one. After 100k it started consuming oil at a rapid rate so I switched to conventional oil and keep it changed regularly. 22k miles later my engine consumes almost no oil. This motor will never see anything but conventional oil.
Old Jul 15, 2012 | 10:53 PM
  #33
partyman66's Avatar
Curious...... what brand and weights of "synthetic" oil did you use during the first 100K and how long and how many miles did you go between changes?
Old Jul 15, 2012 | 11:04 PM
  #34
PAIXAO's Avatar
I used only 5w30 Castrol Edge. Change intervals were between 2500-3000 miles. I bought the car with 28k miles on it. Previous owner used Mobil1 5w30, 3750 intervals.
Old Jul 16, 2012 | 09:44 PM
  #35
Derek173's Avatar
Mobile 1 is a great oil, just doesnt seem to be so great with our engines. I am at 192k mostly using German Castrol and you can usually find 5quarts and a filter at Autzone for under $40 when its on sale.
Old Jul 16, 2012 | 10:09 PM
  #36
dvandriesen's Avatar
german castrol i havent seen at my autzone i guess i need to look closer alwasy go 5w30 full synthetic with kn or mobil 1 filters when on sale.
Old Jul 16, 2012 | 10:22 PM
  #37
TougeMonsterG35's Avatar
Originally Posted by AmateuRN
Which condom is the best?
All work about the same, slight thickness differences. Still need to be changed out. Some can still fail you. One may make you think you're doing better, but its all in your "head".
What the most important thing? Just change it out when you should. No one likes sloppy seconds.
Old Jul 16, 2012 | 10:25 PM
  #38
maximized98's Avatar
I have been using Mobil 1 synthetic for a few years now. I thought that it was good stuff
Old Jul 16, 2012 | 10:57 PM
  #39
CLEANBS's Avatar
castrol 5w30 >>>
Old Jul 17, 2012 | 07:07 PM
  #40
StanG35's Avatar
Hmm castrol or Amsoil....Walmart is currently selling Catrol for $27 for 5 Quart jugs. Amsoil.. they go for about 10 a quart.
Old Jul 18, 2012 | 05:56 AM
  #41
05CoupeMT's Avatar
G35 Coupe 6MT
How many quarts in total does the G35 require when changing the oil filter too...
Old Jul 18, 2012 | 07:53 AM
  #42
faiz23's Avatar
I choose the MIDDLE one for you as the type of oil that suites your car.
Old Jul 18, 2012 | 08:51 AM
  #43
gary c's Avatar
Five! Seriously, would you change oil and not the filter?
Gary
Old Jul 18, 2012 | 09:30 AM
  #44
81gSKy's Avatar
Redline? Motul?
Old Jul 19, 2012 | 02:02 PM
  #45
jrockstarr's Avatar
that condom comments hilarious
