nitrous kit help
Old Jul 27, 2012 | 04:08 AM
kristinavq's Avatar
nitrous kit help
im about to order a dynotune nitrous kit and slap a 35shot on there till i get a tune will i be good ?? im almost full bolt on except headers i dont want to blow or mess anything up .. also will prolly throw on +1 colder plugs does anyone have a part number ?? im most likely going to dyno it before i get the kit so i see whats my a/f ratio whats a good number to be in ?? want to see if im running lean
Old Jul 27, 2012 | 08:45 AM
jgitt's Avatar
if youre going to be doing nitrous you need to get a good a/f ration gauge. The aem uego is the way to go.
Old Jul 27, 2012 | 11:14 PM
eDUBsG35's Avatar
You will be fine with a 35 shot just don't cut corners with the kit. You might want to get a window switch, along with the a/f gauge, you might want to get a nitrous pressure and fuel pressure gauge jus to be able to monitor that. If you plan not to spray to often, then you should be fine with a stock tune, but a tune always helps.
Old Jul 28, 2012 | 12:41 AM
seymore4's Avatar
m56
Good plugs are NGK LFR6AIX-11, please get a tune... at least tune it for your bolt ons then spray, you're most likely running very lean and adding NOS to that is no bueno man
Old Jul 28, 2012 | 04:08 AM
HotRodG35's Avatar
Very inclusive list and great advice, I also suggest a Throttle Position Activation Switch if not included with NO2 Kit because of Drive By Wire TB.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
