Red reverse lights on G35?
Old Aug 7, 2012 | 01:02 AM
fchdx's Avatar
Hello all,
I've been searching the interwebs and I haven't really seen or heard of any G35s who have done this, so I went on Photoshop and did a really quick delete on my reverse lights. (Emphasis on the quick... Literally took me a minute so apologies for the rough edit)
What do you guys think? It'll probably be really easy to do. You'd just need to attach a red vinyl over the taillights.
Old Aug 7, 2012 | 01:13 AM
TORETTO's Avatar
But won't the reverse lights look red
Old Aug 7, 2012 | 01:22 AM
herrschaft's Avatar
Doesn't seem very practical if you ever have to use those lights.
Old Aug 7, 2012 | 01:23 AM
TORETTO's Avatar
People actually use reverse? blasphemy!
Old Aug 7, 2012 | 01:29 AM
Xet's Avatar
Xet
If you want to get a ticket and have to pay out the butt if anyone ever hits you as you back up because your lights will look red
Old Aug 7, 2012 | 01:37 AM
TORETTO's Avatar
I think you can get away with it.
Here are Evolution VII tail lights. The reverse is tinted red. That white line on the bottom is actually the turn signal.
Reverse on:
The white area isn't too noticeable, but when the reverse is on, it should be pretty obvious that it is a reverse light.
Old Aug 7, 2012 | 02:54 AM
Xet's Avatar
Xet
V C Section 24606 Backup Lamps
Backup Lamps
24606. (a) Every motor vehicle, other than a motorcycle, of a type subject to registration and manufactured on and after January 1, 1969, shall be equipped with one or more backup lamps either separately or in combination with another lamp. Any vehicle may be equipped with backup lamps.
(b) Backup lamps shall be so directed as to project a white light illuminating the highway to the rear of the vehicle for a distance not to exceed 75 feet. A backup lamp may project incidental red, amber, or white light through reflectors or lenses that are adjacent or close to, or a part of, the lamp assembly.
(c) Backup lamps shall not be lighted except when the vehicle is about to be or is backing or except in conjunction with a lighting system which activates the lights for a temporary period after the ignition system is turned off.
(d) Any motor vehicle may be equipped with a lamp emitting white light on each side near or on the rear of the vehicle which is designed to provide supplemental illumination in an area to the side and rear not lighted by the backup lamps. These lamps shall be lighted only with the backup lamps.
Amended Ch. 813, Stats. 1981. Effective January 1, 1982.
It wouldn't be adjacent or incidental red, but who knows how strictly they will enforce. Probably depends on if the cop feels like messing with you or you **** them off.
Old Aug 7, 2012 | 09:42 AM
gary c's Avatar
If no one has created a red reverse light there must be a reason. Forget the legality issue, backing up you want to see what's/who's behind you without restriction. Most of us install the brightest LEDs for the safety/visual factor....Gary
Old Aug 7, 2012 | 10:38 AM
driftsucky's Avatar
Red reverse lights, you say. Yeah, that seems like an absolutely horrible idea given the function and purpose of reverse lights. It's as bad an idea as having a white brake light. But hey, you grown. If you want super secret squirel reverse lights, AND you live on the side of the country that I will probably not do much, if any driving in, do you.
Old Aug 7, 2012 | 12:38 PM
Lone Wolf's Avatar
Bad idea. They are white for a reason.
Old Aug 8, 2012 | 09:19 AM
SoulGlo's Avatar
dare to be different
Old Aug 8, 2012 | 10:16 AM
DailyDrivenCoupe's Avatar
i could maybe understand you switching them to amber, but red....
NO.
i agree with gary, i like to be able to see whats behind me when backing up
Old Aug 10, 2012 | 02:05 PM
painttitblak's Avatar
Originally Posted by chsieh
Hello all,
You live in california dude... you should know you will be pulled over right away.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
