Help making steering wheel straight
Old Aug 10, 2012 | 02:46 PM
ericnjttz's Avatar
Ok, so yesterday i installed HFCs and had to move the steering knuckle to get to a bolt. (steering wheel disconnected) When it was all said and done and I tightened everything back up, the wheel was turned 90 degrees while the car was driving straight and the VDC off and Slip lights were on the cluster.
I crawled back underneath to mess with the knuckle again and the closest I could get was the wheel about an 1/8th turn to the right while driving straight. My question is: is there away to adjust the steering wheel from inside the car (I.e bolt by the pedals)?
I don't want to disconnect it anymore in fear of killing the clockspring (already checked it its fine, and all horn electronics still work.)
After searching all last night i now know the steering angle sensor needs to be reset and calibrated and this can only be done at the dealer. However, I still need the wheel straightened as was wondering how else this could be done.
Old Aug 10, 2012 | 03:10 PM
superchargedg's Avatar
The only other way to adjust it straight is to get the toe set on a alignment machine.
Old Aug 10, 2012 | 03:16 PM
ericnjttz's Avatar
There is no shaft bolt....like shown in this video on an 08
Old Aug 10, 2012 | 11:01 PM
gary c's Avatar
Your coupe needs to be on an alignment rack to center the steering wheel....Gary
Old Aug 10, 2012 | 11:53 PM
ericnjttz's Avatar
so on the 03 coupe there is no shaft bolt inside the car like shown in the video on an 08?
also note, this isnt a suspension/steering issue...this is me being an idiot and not centering the wheel on the rack
kd03g99
Jul 30, 2015 11:24 AM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
