Driving Stick Advice
Old Feb 6, 2005 | 02:56 AM
  #61
ScapGF's Avatar
Originally Posted by JZ39
Man, if you guys are chirping from 3rd to 4th, WITH VDC ON, my car must be a dog because, although I've never tried, I find it difficult to believe I could do this if I wanted to!
Therefore, I will try on the way home!
Maybe I need to have my clutch looked at. It just doesn't seem like it grabs anywhere near hard/quick enough to allow for this.
Any luck? It really isn't all that difficult. Make sure you are on pavement where you will be able to hear the chirps loud and clear!
Old Feb 6, 2005 | 03:42 AM
  #62
gaara's Avatar
Originally Posted by ScapGF
Uh, how long have you driven stick for? Its really not all that hard to chirp them when going from 3rd to 4th(in this car, never came close in any other cars ). Although I will give you the benefit of the doubt this time that maybe the dealer didn't properly inflate the tires to the proper PSI. I have only checked one tire and it was slightly low at 32psi
Trust me, I was just as surprised as you are.
Can anyone else back me up on this?
It is highly possible with all that hp and torque. My previous car (2001 prelude 5speed manual) I was able to chirp easily 2nd to 3rd. So I wouldn't be surprised the G chirping 3-4th.
Old Feb 6, 2005 | 01:47 PM
  #63
Lokoto's Avatar
Isn't it true that when the engine is cold (when first driving off for the the day) it is not recommended to shift above 2000 RPM until it warms up?
I feel 3 RPM to be the best for shifting on regular basis but have been experimenting with 2000 which works ok. Have not noticed any improvement in gas mileage with a more conservative approach.
Not to mention the beautiful growl that the G gets at 3RPM. Everybody thinks I am racing when they hear my engine at 3RPM. I guess they are not used to a great engine sound.
By the way,is the engine sound of the G similar to that of the 350Z?
Old Feb 6, 2005 | 03:48 PM
  #64
G35_coupe_6MT's Avatar
Ive driven stick all my life. I hate Auto cars. They are just too boring.
I rather play with the gear and clutch than sit static and press 1 pedal.
Old Feb 14, 2005 | 06:20 PM
  #65
benster's Avatar
first time stick driver over here...question for you more experienced guys
what is the best technique to take off at the line? i'd like to learn something that isn't incredibly complicated and won't cause harm to the engine and clutch.
thanks!
Old Feb 14, 2005 | 06:37 PM
  #66
gaara's Avatar
thanks!
rev to about 5k and drop the clutch
Old Feb 15, 2005 | 02:55 PM
  #67
ScapGF's Avatar
5k? Thats all? Don't you mean we should rev it until it bounces off the rev limiter about 6 times, THEN dump the clutch?
Old Feb 15, 2005 | 03:05 PM
  #68
Finiti35's Avatar
FGC South Florida BOD
And you'll end up with a 3.5s 60'
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
miata007
Aug 17, 2015 04:36 PM
chinee
Aug 8, 2015 10:11 AM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Tonka211
Jul 25, 2015 03:22 AM
