Mass air flow sensor MAF ?
Old Sep 13, 2012 | 10:53 PM
DGrantG's Avatar
What's the best and safest way to clean this sensor? I'm getting a SES light for this sensor and want to clean it safely before dropping $200 on a new one. My car only has 60k miles on it. TIA
Old Sep 13, 2012 | 11:18 PM
ngcamber's Avatar
You want to really careful about trying to clean a MAF. You should NOT use carburetor cleaner or brake cleaner. I think a company came out with special MAF cleaner but I don't know if it is truly safe to use.
There is another product that runs a small hose behind the air filter and connects to a pressurized can that sprays a cleaner into the intake system while you run the engine. I am not sure if it thoroughly clean the MAF.
Fyi - if you are removing the sensor to clean it, make sure you disconnect the battery before unplugging the wires to the sensor.
Good luck with your project.
Old Sep 13, 2012 | 11:32 PM
gary c's Avatar
Most auto parts stores carry spray to clean this sender, unhook/unscrew and remove then spray carefully. Air dry and reinstall. Make sure your air filter is clean, you wouldn't take a shower then put dirty sox on While you're cleaning remove the negative side of your battery to clear the SES warning. Drive your car, hopefully the SES warning is a thing of the past....Gary
Old Sep 14, 2012 | 01:03 AM
partyman66's Avatar
I've been using the Mass Airflow Sensor cleaner spray made by CRC for a while on numerous different vehicles. Never had a problem with it yet... knock on wood.
Old Sep 14, 2012 | 01:04 AM
DGrantG's Avatar
Thanks for the help guys. I'm going to go by the parts store tomorrow and see what they have and by a filter recharge kit. I tried banging all the dust and stuff out of my filter but it may not have been enough.
Old Sep 14, 2012 | 05:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
Me too, never heard of people having issues with it.
G35Rican
Jul 31, 2024 01:37 AM
n2fooz
Sep 4, 2015 07:46 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
