Heads up on the 03-06 coupe headlights
+1 ^^^^^^ we here have a service, for $75.00 which is cheaper than replacing your lights if you are just replacing them for the yellowing....
nah not yellow, just dont want them to get messed up from salt on roads.
If u have a drill, go out and buy a 5$ drill buffer and put some toothpaste on it. spray the light with windex, then use the drill buffer wit the paste on it. no joke works like a charm! and is crazy cheap.
obviously do at own risk. you can youtube it to see results
if ur lenses are ugly color, the toothpaste wont work. go out and get a 20$ headlight kit but make sure it has the scuff/sanding pads. Obviously the drill adaptable one saves TONS of time. they DO work,if you follow the directions.
yoyoyo8
Aug 12, 2015 03:04 AM
