Desiel fuel in my g35 :((((
Oct 28, 2012 | 04:42 PM
So I let my sister borrow my car for the day and she comes home and 20mins later I go out to start the G only to find out it shakes then dies. Of course I knew she put diesel fuel in the car she says she put about 10 bucks of diesel in there, what should i do!?
Honestly considering murdering her in her sleep.
Reply 0
Oct 28, 2012 | 04:47 PM
Kill her, dispose of the body, move to a foreign country with no extradition, finish by changing your name to I.C. Wiener
Reply 0
Oct 28, 2012 | 04:54 PM
Sorry to be the bearer of bad news, but one of my friend told me of a story of how one of their friends put diesel in a scion. The engine was shot and had to be replaced
Reply 0
Oct 28, 2012 | 04:57 PM
It's a scion. They'll not blow a motor for any reason :-P JK
But with little research.
"To get your engine running again, the fuel tank would have to be drained and filled with gas. It might take a few tries, but eventually the engine will be clean of diesel and back in working order."
Reply 0
Oct 28, 2012 | 04:58 PM
That's the cheapest and first plan of action you should take.
Reply 0
Oct 28, 2012 | 05:02 PM
im gunna kill her, its only 10 bucks of deseil tho? should i fill the rest with preimum?
Reply 0
Oct 28, 2012 | 05:11 PM
Quote: im gunna kill her, its only 10 bucks of deseil tho? should i fill the rest with preimum?
How much is diesel in your town. Our cars have a 19 gallon tank and you probably have close to 3 gallons of diesel in there. If you decide to fill the rest with premium chance it'll start but your spark plugs will be shot. Another thing. Diesel is more oil based so it may cause a problem with your injectors....
Reply 0
Oct 28, 2012 | 05:13 PM
Drain the diesel from your tank and then put in premium. Why put in premium with the diesel? If you did that you would still be feeding your engine diesel. And oh yeah, choke the life out of your sister.
Reply 0
Oct 28, 2012 | 05:17 PM
Quote: Drain the diesel from your tank and then put in premium. Why put in premium with the diesel? If you did that you would still be feeding your engine diesel. And oh yeah, choke the life out of your sister.
How can I drain it!? Ive got about 2-3 gallons of desiel in there??
Reply 0
[QUOTE=ilovez33;6611155]How much is diesel in your town. Our cars have a 19 gallon tank and you probably have close to 3 gallons of diesel in there. If you decide to fill the rest with premium chance it'll start but your spark plugs will be shot. Another thing. Diesel is more oil based so it may cause a problem with your injectors....[/QU
I've got around 2-3 gallons of deisel in there.
Reply 0
Oct 28, 2012 | 05:20 PM
Yep Drain the tank. You should also pump out the fluid thats in the fuel lines.
Reply 1
Quote: How can I drain it!? Ive got about 2-3 gallons of desiel in there??
Drop the tank if you are able to yourself, or, take it to a shop on a tow truck. I wouldn't drive the car anymore with diesel fuel in the tank.
Reply 0
Oct 28, 2012 | 05:21 PM
Did you choke your sister yet?
Reply 0
We know you have 2-3 gallons of diesel in there. But it's mixed in with the rest of your fuel. You can't drain just the diesel.
You have to drain your gas tank until it's empty, then put premium back in (preferably a full tank to dilute any residual diesel/gas mixture you couldn't drain out of your tank).
After you put a few tanks of gas through your car, you may still need to change your spark plugs (but in the mean time it would be good to romp on the car a little to try to blow any residue out of the combustion chamber, and it might save you from having to change the plugs).
Reply 0
Oct 28, 2012 | 05:23 PM
You could siphon it out or drop the tank and dump it out...I'd siphon it then add some regular gas to "rinse" it out then siphon that out then fill it up
Reply 0
