My Various Coupe Newbie & Mod Questions - Please Help
Old Dec 22, 2012 | 04:07 PM
blues3531's Avatar
I'd opt for some black or gunmetal rims with a polished lip. Looks awesome on DG coupes. Also I'd match the lip to the car color like another member said. But black grill and rear diffuser are win.
Old Dec 24, 2012 | 09:28 PM
ZGagnon's Avatar
Ill agree with matching the lip. Plan on matching mine
My room is black with black spoiler, black grill with chrome lip. Doesn't look bad at all and have gloss black 19" BMW rims.
So ya I'd match the lip and keep the diffuser stock
Old Dec 25, 2012 | 03:33 AM
LxV Socal's Avatar
Only HID turns on?
Fog lights aren't working Last time I stepped out of my car and saw the headlights,BOTH Top and bottom lights were on.why are only the HID's(TOP LIGHTS) on? tried switching on and off but no luck.only way i was able to turn on the bottom ones is by engaging the highbeams.its an 04 coupe
BTW Happy Holidays everyone!
Old Dec 25, 2012 | 12:50 PM
06G35Coupe94's Avatar
Merry Christmas! Are your fog lights turned off also? also those bottom lights that are always on are your parking lights.
Old Dec 25, 2012 | 03:32 PM
SAMzG35's Avatar
G35
If they are turned on and no output then most likely it's fuse. Check the fuse box under the hood. You need to remove the entire battery cover to have access to it
Old Dec 25, 2012 | 04:42 PM
LxV Socal's Avatar
Yes I've tried flipping the switch on and off and they don't light up on the bottom unless I turn on the high beams,does anyone know what fuse controls the fog lights?
Old Dec 25, 2012 | 05:22 PM
LxV Socal's Avatar
Only the fog lights are turned off,all of the other lights are functional
Old Dec 25, 2012 | 05:33 PM
SAMzG35's Avatar
G35
It's written on the fuse box cover
Check the 5th post by me in this thread
https://g35driver.com/forums/g35-cou...hts-fuses.html
Old Dec 29, 2012 | 06:31 AM
LxV Socal's Avatar
Sorry about the late reply but my fuse box is slightly different and says nothing about fogs other than the relay,all other words are awkward abreviations.
Old Dec 29, 2012 | 12:32 PM
SAMzG35's Avatar
G35
If you drive a G then it cant be different. This box is totally hidden under the battery cover. The whole thing MUST come off in order to see it.
Take a picture
Old Dec 29, 2012 | 03:16 PM
LxV Socal's Avatar
Take a picture
As you can see the top left fuse that you pointed out in the picture(fuse # 71) is the fuse for the tail lights
and also the picture you pointed out didn't have any relays on the left side
If anything Its the 2nd to the bottom one but I changed the fuse out to a brand new 15a and still nothing I took out all of the fuses and they all look fine.Is there another solution to figuring out what the problem is?
Old Dec 29, 2012 | 08:14 PM
SAMzG35's Avatar
G35
My reply in post #6 was to show the fuse box location not the issue with your problem. Fuse 71 was for the other thread.
But yeah I was pointing out that second fuse bottom right. If you changed that and it didnt work then its definitely something else. Have you checked for power at the fuse box? If not could be a bad switch maybe?
Old Jan 2, 2013 | 02:21 PM
LxV Socal's Avatar
Anyone know a place where I can get this fixed in So Cal
Old Jan 7, 2013 | 01:50 AM
LxV Socal's Avatar
bumppp...still can't find out what the problem is
Old Jan 7, 2013 | 03:15 AM
  #30
LxV Socal's Avatar
problem fixed! damn fuse at pep boys was a dud.Got one at a local car swapmeet and fogs work now.Please close thread.
