Will a 350Z engine fit into my G35 coupe?
Old Nov 4, 2012 | 07:11 PM
Hiro's Avatar
Hey guys,
Just wondering if a 2004 350Z VQ35DE non-revup engine will fit into my 2004 G35? In case you are wondering, I have my American spec G with me here in the UK. I need a new engine because my botten end bearings are going out. Its either rebuild or get a newly rebuilt 350Z engine. I can't get a rebuilt G35 engine since they never sold the Infiniti G35 here in the UK. I figured its the same engine so it should fit right? If there's anything I should know, please leave comments. Thank you.
Old Nov 4, 2012 | 07:13 PM
JaE35's Avatar
Moderator
G35 Sedan
Will fit and work fine..just transfer over your original harness
Old Nov 5, 2012 | 12:22 AM
06G35Coupe94's Avatar
Umm.... haha sorry, sorry.... Yes itll work. Its the same engine.
Old Nov 5, 2012 | 10:23 AM
driftsucky's Avatar
It's a direct bolt-in.
Old Nov 5, 2012 | 11:54 AM
Revo's Avatar
Identical block - direct swap. As a prior poster said, use your car's own harness.
Old Nov 5, 2012 | 12:18 PM
jutn35's Avatar
G35 Coupe
the 350z engine has alittle more HP than the G35 spec engines.
Old Nov 5, 2012 | 12:34 PM
jhatfie4's Avatar
Not exactly. The engine is identical, the 350z's ECU has a slightly more aggressive tune which makes the 350z put out a few more HP
Old Nov 5, 2012 | 04:36 PM
driftsucky's Avatar
Yeah. hp that you'll never feel. It's like 20more TO THE CRANK. LOL
Old Nov 5, 2012 | 04:41 PM
JaE35's Avatar
Moderator
G35 Sedan
don't buy into that garbage, had to feel bad just typing that lie lol...it's lighter by a tad yes but more horse NO
Old Nov 5, 2012 | 05:07 PM
Hiro's Avatar
Hey guys,
Just wanted to say Thanks for all the informative posts. Everything is such a hassle here in the UK. I feel relieved that I can do the swap without any issues. So, basically I just need to keep my engine harness from the G when I do the swap right?
Now another question, I called an Infiniti dealership in the states and asked if a Z engine will work in a G. Of course, they don't know if it would work or not. They told me they are not sure if it will work, but if it does...I will definately need to change the oil pan and the exhaust manifold. Does that information sound legit?
Since I've been out of the states for so long now, I'm really unfamilar with the prices there. The company that has the engine here is selling the refurbished Z engine for 2K pounds. That is about $3200. This price includes the engine and the install. Is that a good price?
Will I need to retune my car afterwards?
Also, will a Rev-up engine work for my 04? If it does, would you stay nonrevp or go revup? I'm assuming HR is out the question right?
Thanks for your help.
Old Nov 7, 2012 | 03:26 PM
jhatfie4's Avatar
you can't use the rev-up because the non - revup harness doesn't have plugs for the Variable Exhaust Valve Timing that defines the rev up motor.
vmcarbuyer
Oct 12, 2019 12:42 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
