Any different Jack Points for the OEM front lip installation?
Old Jan 22, 2005 | 11:00 AM
dennis_said's Avatar
Hi guys,
I'm going to be installing my front lip today, and I am curious if I just use the two jackpoints at the front that I normally use to swap out wheels... or if there are better points (maybe towards the front of the car) that are safe and more suitable for the front lip installation?
Thanks
Old Jan 22, 2005 | 01:59 PM
kenchan's Avatar
You can actually just use a ramp if you have one. -or- the same jack points you
indicated. Make sure you use an adapter if you're going to put the car on jack
stands as the rail along the side of the car will eventually break if you set
the car on it. And use wheel chocks.
Old Jan 22, 2005 | 06:59 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Look in the owner's manual - there is a section illustrating the two jacking points for the floor jack.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
DRG35R
Jul 31, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
