Throttle body coolant bypass? Needed or not
Old Nov 8, 2012 | 12:19 PM
Silencer_0's Avatar
^ Correct, that coolant hose is there just to warm up the throttle body and plenum.
Old Nov 8, 2012 | 12:22 PM
jhatfie4's Avatar
yes it is there to keep the TB from freezing. It warms the TB up...
If it's not cold where you live then you can bypass it with the advantage of flowing a slightly cooler, denser intake charge.
Old Nov 8, 2012 | 07:41 PM
smokedG35's Avatar
cool thanx for the input. hopefully soon ill get a z tube and plenuem spacer.
Old Nov 9, 2012 | 03:49 PM
06G35Coupe94's Avatar
If people use the search function they'll find it. Since I've been here I've only seen this question come up a few times. This thread will always be here lol it's not going anywhere
Old Nov 9, 2012 | 05:04 PM
Originally Posted by PlastiDippinG
Dude are you like thread stalkin me or something? Every time i comment somewhere, u instantly pop up on the thread and say some weird comment and dont understand what im sayin while everyone else does.
Seems to me like you are spam whoring, trying to just get your posts up. Not cool bro
Lol I just like to troll the new guys because they ask commen sense questions. I comment on all new threads. Som I give very helpful info. Others I like to teach people how to search and use the forum. Not just post every question you have...
Old Nov 9, 2012 | 09:14 PM
crazynuts16's Avatar
what about the copper iso thermal spacer?, is the coolant bypass valve better because it can completely cut-off the coolant from the throttle body?
Old Nov 10, 2012 | 03:08 PM
I would think it is better because there is less heat unlike being in the throttle body but I'm not 100% sure. Hopefully someone can chime in. It could be and do the same thing also.
Old Nov 13, 2012 | 09:14 AM
jhatfie4's Avatar
What do you mean "is it better?". They are two different things completely. The TB bypass valve makes the throttle body cooler. The Iso Copper Plenum spacer keeps the engine heat from conducting from the lower to upper plenum. I think both have neglible effects because the TB is small, and in the case of the Iso - that heat is still somewhere (lower plenum).
Old Nov 13, 2012 | 10:52 AM
gary c's Avatar
So many question about keeping your plenum cool? If you live in the south/west United States you need the TB bypass/copper gasket to keep your plenum cooler during hot weather! Our VQ motors love cool which is evident by how easily SLICK lights up my new Michelin's this time of year. Spacer corrects Nissan's design error, TB bypass ISO keeps everything cooler....simple!
Gary
Old Jan 12, 2022 | 02:13 AM
Gunguy86's Avatar
I35
Originally Posted by smokedG35
Yea i know that i was saying with no bypasd the hose is there just to keep that stuff from freezing
I've been working on these cars more specifically the engines for a while and what the throttle body coolant lines do is they warm up the throttle body, the benefits of this are that in colder weather the engine won't have to use so much more fuel because with the throttle body warned up it increases the temperature of the air intake charge enough that it keeps the engine from running to cold and running rich or throwing a code for temperature to low. As everyone else said though these engines do like colder air, so get a valve installed so in warmer months you can turn the coolant flow off and then back on in colder months. People seem to to forget that colder air requires more fuel so the air/fuel ratio is correct. Hope this helps you. If you need anymore car advice feel free to add me on Facebook. Mark Auber
Hasanbaloch
Feb 29, 2024 08:45 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Phenomenon9
Aug 9, 2015 01:34 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
