'05 Rev-Up Engine Rebuild
Old Nov 9, 2012 | 07:01 AM
HereKittyKitty's Avatar
My car has been diagnosed with oil consuming issues. Now at the time of purchase it came with a transferable warranty(Non-Nissan). This party will be paying, partially, for the rebuild.
My question, what should be changed / fixed on this rebuild in order to stop and or lessen the oil consumption issues?
65,000 miles coupe with 6mt.
Thanks, HKK
Old Nov 9, 2012 | 07:33 AM
DailyDrivenCoupe's Avatar
see if they will float you the cash for this --> http://www.z1motorsports.com/350_g35...oducts_id=4265
kinda weird they give you the money to rebuild, im guessing thats because of the aftermarket warranty
Old Nov 9, 2012 | 01:35 PM
serges's Avatar
Thats a nice rebuild kit! Wondering if I should do the same on my 06 that eats oil like a ****?
Old Nov 9, 2012 | 03:58 PM
Darkstar752's Avatar
How bad is the oil consumption? All 05-07's have OC, it's just a question of how bad it is. Mine is only 1qt per 4000 miles so I just let it go. Also, how much is partial payment, 50%?
Old Nov 9, 2012 | 04:32 PM
serges's Avatar
Mines pretty bad about a quart every 6-700 but runs absolutley perfect! Im just afraid to bring it in cuz I know im down 2-3k easy already!
Old Nov 9, 2012 | 05:04 PM
1/4-1/2 a quart per 625 miles, runs great. Paying 50% for the rebuild.
Old Nov 10, 2012 | 08:13 AM
serges's Avatar
Thats cool u gunna use that kit above?
Old Nov 10, 2012 | 04:10 PM
Still looking into all the details of the rebuild, keep ya posted. More info Monday.
Old Nov 10, 2012 | 05:45 PM
TemjinX2's Avatar
I would just go with the rebuilt short block from importpartspro
Old Nov 10, 2012 | 06:52 PM
Ok, please detail as to what is replaced on a short-block! Thanks!
Old Nov 11, 2012 | 07:42 PM
06G35Coupe94's Avatar
Replaces the lower part of your engine. Crank, rods, and pistons. Search importpartspro, and look at their engine packages. Also great prices
Old Nov 12, 2012 | 02:53 PM
Getting the engine rebuilt at a cost to me of $ 2500, all that needs to be changed will be fixed.
Old Nov 13, 2012 | 12:17 AM
TemjinX2's Avatar
Here's a copy and paste from the website http://www.importpartspro.com/st1blon.html
stage 1 block build $2600. You can tell them just to go stock compression if you don't want to turbo in the future.
Product Description
This Stage 1 VQ35 Block is good for someone who wants a safe turbo charged or super charged Nissan 350z or Infiniti G35 without the worry of detonation. The stage 1 package is good for up to 650 Rwhp(We strongly recommend a sleeved block for over 650 Rwhp). The Stage 1 VQ35 block comes with a full one year warranty against machining defects and comes with our 10+ years experience on building Nissan/Infiniti motors.
This package includes:
Wiseco Pistons .020 over
Eagle/SCAT H Beam Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block prepped and assembled
Old Nov 13, 2012 | 12:41 AM
faiz23's Avatar
Stop wasting time and getting your self into headaches. Who will be putting the shortblock together and moving over timing components. Are these guys certified or even experienced to work on VQ engines specifically revup which has intake and exhaust timing. Call up courtesy nissan and tell them you want the online/g35 driver discount. You will be out of state and save on tax but cough up like $250-500 in shipping I would imagine. Just buy a crate motor and drop it in since it comes with all new timing components and ready to go. Have fun torquing the heads, mating the surface, assembling to spec, blueprinting/balancing, moving over timing and setting it correctly. Oh who is planning on replacing all the old worn out tensioner, oil pump and fun stuff......
http://www.courtesyparts.com/10102-e...t-p-15212.html
http://www.courtesyparts.com/10102-e...-p-614361.html
http://www.courtesyparts.com/10103-e...t-p-15216.html
Freeman186
Sep 6, 2023 10:07 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
Jnm07
Sep 5, 2015 01:16 AM
