Hi,
Yesterday, i have notice something strange about my temperature for the climate control.
I was driving my gf, and she suddenly told me that it was so hot in the car. So i checked what temperature the fan was at, and it read 21 degrees celcius(im from canada).
So then i lowered it 18.5-19 celcius and the temperature didnt drop at all. It still felt really hot. So then i flicked it to 32 celcius(the maximum temp) and it felt exactly the same when i was at 21 celcius. So right now basically from tenperatures 18.5-32 degrees celcius is all the same temperature.
I was just wondering if anyone had this issue or know how to fix it. Because i dont want to take it to the dealership.
Thanks
Thanks
Probably a bad circuit board in the back. I had a similar issue, but it was the AC that was on not the heater. Maybe go aftermarket deck?
Quote:
found the problem. Apparently it was some wire that was disconnected under the steering wheel. Originally Posted by sjsharky4
hey ... I have the exact same problem. What wire under the steering wheel was it? Can you let me know where you found the wire. Thanks!
