Question on G35 coupe SPC rear camber kit
Old Nov 26, 2012 | 02:31 PM
G35DG's Avatar
hey guys,
I posted this in the Tech Area but got no reply......so hopefully one of you can help me out in the General Discussion area.
My question is regarding the SPC rear camber kit on my 2006 G35 coupe 6MT.
I have the car lowered by 1"-1.5", and installed the SPC rear camber kit. After going to an alignment shop, they told me that they can adjust the toe back to 0 degrees but the best they can do on the rear camber was -3 degrees.
After some investigation, I realized that the rear camber arms were installed properly but I did not elongate the toe bolt area (by the rear control arms).
I have two questions:
1) What is the best camber I can get if i go through the extra effort to elongate the toe bolt area?......the SPC box says +/-4 degrees on camber, so does that mean i can actually bring the rear camber back to -1 or even zero?
2) My toe is now back to factory specs at 0 degrees, how detrimental is it to my tires if i continue to run at 0 degree toe and -3 degree camber.
Thanks guys!
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
