downshift rev matching and using the clutch
Old Nov 20, 2012 | 01:36 PM
LxV Socal's Avatar
does anyone else take off on 2nd gear?
I feel that 1st gear is extremely short and meanwhile I'm shifting to second smoothly, everyone that is auto is passing me up
Old Nov 20, 2012 | 02:31 PM
jstudrawa's Avatar
Depending on the car, many do exactly that. Or skip a gear.
For example, in my 5-speed Xr7, I never use 4th. 3rd goes to 110, so I pop right to 5th for 80mph, 2k rpm crusing Or 2nd most times, since I run 1st to 40 then 3rd for city driving.
Old Nov 20, 2012 | 02:35 PM
irishsig's Avatar
Yep, I do the same.
1st gear is just so short, especially when ur just cruising.
Old Nov 21, 2012 | 11:55 AM
ss284's Avatar
All the time.
People say it puts more wear but I think there's less wear then when shifting any gear normally
Also helps if you have an exhaust like myself an need to keep it quiet around a cop
Old Nov 21, 2012 | 01:22 PM
partyman66's Avatar
Not on my G35, but I do skip gears almost all the time.... usually 1/2/4/6 or 1/3/6.
I wish our cars were geared a bit taller... particularly 6th.
Old Nov 21, 2012 | 08:50 PM
saywat?'s Avatar
nope ill only do it if the cars rolling a bit and wont let me shift to first. OP u must do alot of revving lol if ur always starting in second
Old Nov 21, 2012 | 08:58 PM
tylerxfire's Avatar
sometimes..depends on the circumstance..
Old Nov 23, 2012 | 11:50 AM
machambe's Avatar
In traffic if i'm already rolling a bit i'll skip 1st but the only gear i skip on a more regular basis would be 4th... idk my dad used to do it when i was growing up guess i picked up the habit
Old Nov 23, 2012 | 03:52 PM
HereKittyKitty's Avatar
Not much of a skipper car nor bullett bike!
Old Nov 23, 2012 | 05:41 PM
2one8's Avatar
Originally Posted by ss284
All the time.
not more wear on the trans, but it can cause more wear on the clutch. Typically when people start out in 2cnd theres a longer engagement time.
Old Nov 25, 2012 | 01:55 PM
macintos's Avatar
Cold or ice on the roads and I do that to keep traction. Usually skip gears when reving high for some reason.
Old Nov 25, 2012 | 08:47 PM
902g35Liam's Avatar
hmm.. being a fairly new standard driver.. i thought for sure this would be bad for the car/trans... i do find the 1st-2nd shifting seems slow though when you shift smooth definately looks funny when 1st-2nd cars pass me when im driving smooth, then i stay in second for a few extra seconds and pass them into 3rd
Old Nov 25, 2012 | 09:38 PM
mycoolg's Avatar
Letting off in 2nd isnt that's bad but if constantly done, your clutch will wear out faster than normal. I almost never skip a gear upshifting, to me the car drives a lot smoother that way. But downshifting I almost always go 6-5-3-N just drivers prefence.
Old Nov 26, 2012 | 06:51 PM
PlastiDippinG's Avatar
lot of people have a hard time getting used to our clutches, the spring removal or other mods make it easier to start from 1st gear.less travel,less jerky
Old Nov 26, 2012 | 09:30 PM
LxV Socal's Avatar
So i have had my car for about 3 months now and it is a 6 spd mt...I drive it everysingle day(mostly freeway) and so far so good clutch feels strong,no slips or grinding gears,but I had a question.let's say I was going about 50 mph on a highway and I wanted to go to a stop because of a red light,when I down shift I rev match when I can but how am I supposed to rev match use the clutch and the break at the same time while coming to a hard stop? Is it better to just put it in neutral and brake? Because I am aware that letting the clutch(not using pushing the gas pedal) out slowly while downshifting is bad for your clutch because you are burning it.so what would be the correct procedure for coming to a hard stop at like 40-50 mph?
