Where to buy a replacement performance engine?
Thanks for the lead Bigc. I'll check out my350z forum for more info.
Hey Dark-Knight! I don't know if its you or not, but I saw a black G on youtube a while back. Pretty cool video in my opinion. Just wanted to give you some props![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Just curious, but why would people opt for the short block only? It seems like it would make sense to get a fully built longblock if you were going to replace the engine. I have a lot of miles on my G so I'm going the longblock route, but how dependable are the stock heads and cams? How much power are they good up to? I know the block is supposedly 400hp. From Dark Knight's experience, shouldn't his force induceted engine have lasted longer than 27K miles? Hmm....again thanks for all the comments. Feel free to keep the posts coming.
^Stock heads are good to around 500+whp, only those looking for big numbers need to worry about them. Although I probably would do everything with a high mileage motor. As far as an engine lasting, a correctly built setup with a proper tune should last a long time.
![28](https://g35driver.com/forums/images/smilies/28.gif)
Engine was stock. I knew I was on borrowed time but was hoping it would last a little longer so I could save up for a built block. Now its time to get serious. If what you say about the head is true then you just helped me make up my mind. Was researching to see if I really needed to upgrade my head to get to 600+ whp. I was originally going to go sleeved block and just rely on higher boost to make the power. Did you read that somewhere or have personal experience with that engine set-up?
Thanks again for all the posts. When I read the posts sometimes I read where someone says whp instead of hp so I forget they are talking about power to the wheels. If all the info here is correct so far, it looks like ImportPartsPro (IPP) is the way to go. I don't plan to go over 600Hp to the crank. I was thinking about the new GTM turn-key supercharger kits with either 500 or 550 Hp. I figure after drive train loss, I should be around 430 to 490 at the wheels (whp).
With that being said, it seem as though the stage 1 longblock from IPP should fit my needs. The only difference I see between the stage 1 block and stage 2 block is the upgraded cams. Is there any advantage to this? I know nothing about cams so would it be beneficial to for me to pay the extra $1K or so for this upgrade?
This is a bit off topic, but from what I read about the Vortech, this particular supercharger is capable of up to 404 for non rev engines and 440 for rev-up engines. This is crank (hp) so power to the wheels (whp) would be in the 300's or so. Is this the full capability of the vortech? If so, I don't see the point in going with this supercharger compared to the one from GTM. If I'm going with a built engine, I might as go with more power if possible right? I see the vortech as an option if someone were to stay with stock heads and block, but correct me if I'm wrong.
Also, if Dark-Knight is going with a stage 3 long block from IPP, his current vortech wouldn't give him the power gains he would desire right?
Does anyone have a link of what upgrades are necessary for increased power gains if going with supercharged engine? Not considering turbo at this point, but could change my mind if conviced otherwise.
For example:
300 Hp - stock engine, exhaust, ART or HFC, etc...
350 HP - ...........
400 HP - vortech, etc...
450 HP - HKS supercharger, fuel pump, etc....
Just an example above, but, if anyone has a link for this info....I'd appreciate it.
Thanks
For example:
Thanks
^ The base vortech kit will give you ~350whp, but has a lot more headroom. With the 2.87 pulley, many folks on here and my350z have gotten low-mid 400 whp, and although less common, people have pushed into the upper 400s (at the wheels) with impeller upgrades and/or upgrading the blower (vortech has a bunch of different blower trims).
Skim through this thread before passing on Vortech: http://my350z.com/forum/forced-induc...-new-post.html
^ Relatively speaking it is kinda expensive but so are most upgrades for this platform. But the idea of getting muscle car performance from such a sexy looking car makes it worth it to me. We could easily sink 9k into (insert V8 powered domestic) and make more HP, but then you will just be like every other muscle car owner. Guess it all comes down to what makes you happy when you step into your garage.
I'm running a single Garrett GT35R turbo. This kit is supposed to be capable of just over 600whp with all the "supporting upgrades", guessing that means fuel system, boost controller and tuning. I'm sure upgraded heads won't hurt either.
