Help please
Old Dec 22, 2012 | 08:38 PM
alxn91's Avatar
Help please
I installed my plenum spacer and the bypass coolant, when I went to try to reset the ECU I hear a clicking sound everything I hit the gas. Also when the car is running I hear a knocking sound. Can somebody help me, please.
Old Dec 23, 2012 | 01:20 AM
06G35Coupe94's Avatar
Check all your hoses and the rubber part around the oil cap. Check to make sure you torqued all the bolts down
Old Dec 23, 2012 | 02:10 AM
SAMzG35's Avatar
G35
Did you add the black plastic pieces into the plenum where the bolts go? Could it be that one of them moved? does it get louder when you rev?
Old Dec 23, 2012 | 11:02 AM
Eno's Avatar
Eno
Post a video if you get a chance-
Old Dec 23, 2012 | 09:33 PM
gary c's Avatar
I dislike unwanted noises too! Reread the instructions and start over removing everything. Kinda sounds like one of those center spacers got loose. They would make the noise you describe being sucked down the plenum....Gary
Old Dec 28, 2012 | 10:54 PM
alxn91's Avatar
I took my plenum apart and re-installed the spacer from scratch. All good now I dont have the noises any more, thank you for the responses.
Old Dec 29, 2012 | 12:17 AM
gary c's Avatar
There's some good news, glad you fixed that noise....Gary
Old Dec 29, 2012 | 12:31 PM
SAMzG35's Avatar
G35
I'm pretty sure one of these wasnt sitting properly
Glad you got it fixed
