Single mass conversion
Old Dec 27, 2012 | 04:31 PM
WhiteCruzG's Avatar
Alright guys, I need some help. How hard is it to switch from dual mass to single mass? And what is required? All I can find are the pros and cons between the two… any help would be greatly appreciated. Thanks in advance.
Old Dec 27, 2012 | 05:19 PM
jhatfie4's Avatar
there is nothing to be converted. you just replace your stock flywheel with the single mass one. of course replace your clutch and throwout bearing at the same time, just like always
Old Dec 27, 2012 | 05:46 PM
WhiteCruzG's Avatar
Awesome just replace the clutch and flywheel at the same time and should fit fine? Plug and play basically?
Old Dec 28, 2012 | 07:09 AM
Hiro's Avatar
Should be pretty easy. Just be ready for the chatter sound at idle. How much will depend on how heavy your single mass is. Also, if I'm not mistaken, I want to say it grabs a little quicker as well with a single mass flywheel. Not a big deal really. You will get used to it quickly.
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
