VTC Solenoid Oil Passage location
Old Jan 5, 2013 | 05:49 PM
Darkstar752's Avatar
Hey guys, I have a knock coming from my engine that's only apparent when warm. The knock is most audible and very loud with a stethoscope when placed on the VTC solenoid, specifically the brass part, on the tip closest to the fender. I'm guessing the knock is being transmitted up through the oil passageway, probably the ones closest to the brass part.
Does anyone know what component(s) these passageways lead to? Thanks!
Edit: 2006 Rev-up engine btw.
Old Jan 5, 2013 | 07:07 PM
faiz23's Avatar
The knock could be the vtc solenoid it self. Look up vtc solenoid issues with s14,s15 and 300zx. You can ground the solenoid and see if the issue goes away. Also what you could be mistaken for a knock around vtc but it could be a timing chain guide or tensioner. Also just throwing it out there but with rev up the weakness in the engine is piston rings and valve guide seals.
Old Jan 5, 2013 | 08:11 PM
Thanks man. I replaced the offending VTC solenoid yesterday with no change in the problem. It only happens when the engine is warm, near silent at cold. I've tried to trace the passages, seems like 1 goes past cylinder 1, hope it's not a worn bearing. There's multiple noises at once it seems, possibly low oil pressure. The knock just seems extremely loud from the solenoid.
Muski_G
Dec 1, 2023 11:11 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
KevinnnVo
Jul 28, 2015 06:29 PM
