Break Booster hose stuck?
Old Jan 8, 2013 | 12:22 AM
verbov's Avatar
So I was trying to seafoam my car today through my break booster hose; I got the butterfly clip open but the hose wouldn't seem to come off. In the video I saw the dude took it off pretty easily.
I have a 2004 6MT. Thanks in advance!
Old Jan 8, 2013 | 12:28 AM
herrschaft's Avatar
Have you tried twisting it back and forth to help break it loose? Mine was also a PITA to get off.
Old Jan 8, 2013 | 12:32 AM
verbov's Avatar
I mean I tried using force but I'm just a little scared. I don't have much experience under the hood and I don't want to damage anything..
Old Jan 8, 2013 | 03:09 AM
Darkstar752's Avatar
It's vacuum sealed so you need to pull decently hard. It will come off with a resounding POP. Twist it back and forth with a wrench to loosen it a bit, then pull with your hand.
Old Jan 9, 2013 | 04:56 AM
JDMswagSerf's Avatar
use a thin flat head or a thin pin and put it between the hose and connector and try to move the flathead or pin around the hose and fitting. a little bit at a time so the hose won't rip.
Dallsinghjr1
Sep 17, 2023 11:25 AM
prinny
Nov 22, 2015 11:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
