G35 Shift Kit
Old Jan 19, 2013 | 12:08 PM
G35JdmFan's Avatar
G35 Shift Kit
hi hopefully I posted in the right section if not mods please move thread to proper section and not close this thanks,
so I had an extra shift kit laying around that I'd like to make it fit onto my g35 coupe 2003 im just not sure how and what I need
Posted from G35driver.com App for Android
Old Jan 19, 2013 | 12:19 PM
G35JdmFan's Avatar
here are some pictures sorry I used the android app to post this...
http://up.ht/UXD1B0
http://up.ht/UXCZJk
Old Jan 19, 2013 | 12:20 PM
G35JdmFan's Avatar
http://up.ht/UXCZJm
http://up.ht/UXD1B2
Old Jan 21, 2013 | 08:52 PM
G35JdmFan's Avatar
anyone could help me out ? google searches leads to nothing...
Old Jan 21, 2013 | 09:02 PM
JaE35's Avatar
Moderator
G35 Sedan
you need to use imageshack.us to upload your pictures...this service you're using is terrible
Old Jan 21, 2013 | 11:31 PM
G35JdmFan's Avatar
yeah I know im sorry as I said I do not always have a computer/laptop whit me as im always outside im currently using the android app which isn't very effective...
Old Feb 5, 2013 | 04:35 PM
soweidan's Avatar
hi every one, can some one tell me where can i get the shift kit from? i did some research but they don't cary ones for infiniti g35? thx https://g35driver.com/forums/images/smilies/dunno.gif
Old Feb 5, 2013 | 04:43 PM
DKano's Avatar
This is the one I had installed on my car:
http://www.summitracing.com/parts/tr.../make/infiniti
Old Feb 6, 2013 | 03:17 AM
jutn35's Avatar
G35 Coupe
what are these for ^ ?
Old Feb 6, 2013 | 02:41 PM
DKano's Avatar
It makes your car shift faster and makes your shifts a little firm which will make you spin your tires when shifting to second or third most times if you're giving your car a little extra gas. I've had it on my car for a little while and am very happy with it!
Old Feb 6, 2013 | 05:44 PM
06G35Coupe94's Avatar
This is probably the best mod for an auto G hands down. I can't wait to buy one
Old Feb 6, 2013 | 06:33 PM
jutn35's Avatar
G35 Coupe
how invasive is this mod, do you have to drop the tranny ?
Old Feb 6, 2013 | 07:29 PM
HotRodG35's Avatar
It allows higher pressures applied to pistons which compress clutch discs quicker for better engagement with less slippage. There are 7 different sets of clutches in the transmission, primary ones are the Input Clutch and Direct Drum Clutches.
Trannys from factory are designed to engage clutch discs slower for a smoother shift, which actually causes the clutch discs to slip longer, more heat build up. Shift kit actually improves life of transmission.
Does not require tranny removal. Just drain trans fluid, remove tranny oil pan and follow directions for removing Valve Body.
Study directions thoroughly and work in a clean enviroment.
There are some DIY threads for guidance
https://g35driver.com/forums/engine-...y-upgrade.html
JG_G35
Accessories
Feb 25, 2016 01:44 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
nervseele
Jul 17, 2015 11:21 PM
