O2 Sensor help
Old Mar 6, 2013 | 02:17 PM
dragonv's Avatar
O2 Sensor help
I have codes p1167, p1166 and po159 which seem to read Heated oxygen sensor 2 bank 2, heated oxygen sensor (bank 2 sensor 2) lean shift monitoring (bank 2) and 02 sensor circuit slow response (bank 2 sensor 2). Are these something I need to replace right away and will CEL turn on again if they are problematic since I just reset the ecu to clear the codes.
Old Mar 6, 2013 | 09:20 PM
seymore4's Avatar
m56
I would say you need a new O2 sensor
Old Mar 6, 2013 | 10:49 PM
gary c's Avatar
Any time you're throwing an error code you need to fix what ever's causing it!
Gary
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
