bcm problems
Old Mar 18, 2013 | 12:55 PM
wcslax8932's Avatar
bcm problems
okay bare with me because I am new. but I bought a bcm for my 04 coupe 6mt off a wrecked g35 it was tested and everything. I took it to infiniti to get put in after they installed it it worked for about 6 hours then stopped again. does anyone know what could be wrong?
Posted from G35driver.com App for Android
Old Mar 18, 2013 | 01:25 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
are you sure it was the same part number as the one your car took?
if you can give me the VIN for your vehicle I can verify the BCM number, and if that's not the one you have now, it's not going to work
~Phil~
Old Mar 18, 2013 | 04:11 PM
saywat?'s Avatar
im guessing infiniti would've confirmed its compatibility prior to installing it for the owner
Old Mar 18, 2013 | 04:51 PM
wcslax8932's Avatar
I matched the part number with my factory bcm. and made sure that I asked if it was compatible. it worked perfect for probably 6-7 hours and then just stopped. I'm thinking it could be wiring harness maybe? or they programmed it wrong? my vin is JNKCV54E44M823805. thank you
Old Mar 18, 2013 | 05:06 PM
PREMIUM SPONSOR
Factory Part Number per VIN
284B1-AC361
it could be the wiring harness, could be the part isn't any good after all....
~Phil~
Old Mar 18, 2013 | 05:14 PM
wcslax8932's Avatar
Okay the one that was in my car before was 284b1-ac301. But you're sayin it's 361 so maybe its the wrong one. Or do you know where to get a wiring harness? Other than the dealership
Old Mar 18, 2013 | 05:50 PM
PREMIUM SPONSOR
the AC301 has to be 361 there's no 301 so mabye the 0 is messed up a little...
however, talked to a tech, and you need to go back to the dealership, see if it's a possible ground strap issue
Old Mar 18, 2013 | 06:19 PM
wcslax8932's Avatar
I really appreciate all your help. I will get back to you after I go to the dealership and let you know if that's what it was
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
Danielek
Sep 10, 2015 06:18 PM
