Auto Window Problem
Old Mar 25, 2013 | 05:48 PM
bandit5001's Avatar
Auto Window Problem
Ok this may have been discussed before but I searched and didn't find anything, so here it is. My 04 Coupe has a problem with the drivers window if I hit the auto up it goes up and then it drops back down about 3-4 inches. I saw somewhere that someone posted that there was a limit switch that needed to be reset but I didn't see it when I popped the switch housing off so I am wondering it it is the regulator that is bad? Please any help is appreciated
Also my drivers door will not open or close with the fob should I just get an aftermarket lock or what? What's the best fix for this?
I have to get the car ready for sale because I have a wedding to pay for
Old Mar 25, 2013 | 06:06 PM
KrazySouthG35's Avatar
I have the same exact issue with my windows somebody's gotta know
Old Mar 25, 2013 | 06:16 PM
BlkCoupe's Avatar
Unfortunately the reset button is at the window regulator motor. You must remove the door panel to access the button.
Old Mar 25, 2013 | 07:32 PM
leonardo_06G35's Avatar
This is straight out of the service manual, I had the same problem it worked perfect for me..
SETTING OF LIMIT SWITCH
If any of the following work has been done, set the limit switch (integrated in the motor).
  • Removal and installation of the regulator.
  • Removal and installation of the motor from the regulator.
  • Operate the regulators as a unit.
  • Removal and installation of the glass.
RESETTING
After installing each component to the vehicle, follow the steps below.
1. With the door open, lift up and hold the power window switch until the door glass is fully closed.
2. Get inside the vehicle and close the door.
  • You need to close the door so the door switch is fully depressed.
3. Press and hold the reset switch. While holding the reset switch, press down and hold the power window switch until the door glass is fully opened.
4. Release the reset switch.Then, lift up and hold the power window switch until the door glass is fully closed.
5. Open the door to release the door switch. The door glass should partially move down.
CAUTION:
  • Do not use the window auto function.
  • Do not release the switch before the window is fully stopped.
Old Mar 26, 2013 | 06:04 PM
bandit5001's Avatar
WOW, I have been living with this issue for over a year and it was a 10 min fix. Thanks for the help.
Now on to that locking mechanism what should I do to fix this
Old Mar 26, 2013 | 07:35 PM
Glad I could help.
Old Mar 29, 2013 | 08:50 AM
COBRA ESQ's Avatar
This will be my third time in two years that I need to do this! Anyone know what causes the issue?
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
