mm/quarts for oil consumption
Old Apr 6, 2013 | 12:36 PM
Scho8fer's Avatar
Hello,
I looked up the TSB from 2010 for oil consumption, it mentions 8 mm low on the dipstick to fail the test.
Does anyone know how many quarts it is for the 8 mm mentioned in the TSB?
I called a couple of dealers near here and they all mention quarts not mm. Called Infiniti and they won't tell me, only that its probably normal for my mileage (50k miles).
The car is a 2007 coupe and the powertrain ends. I'm actually going back for the second test today.
Thanks!
Old Apr 6, 2013 | 11:07 PM
bakwoods's Avatar
The cars take 4.5 qts to fill. Best way to check your consumption is actually by letting it sit overnight and checking the dipstick when the car is cold. The reason I say that is because the oil flows right down past the dipstick and therefore you don't get a completely accurate reading immediately after an oil change.
However oil consumption is normal in these cars. I guess the only real way to tell is to do an oil change and only fill one quart, wait till it settles overnight and get a reading, that'll be your base reading. After that fill the other quarts the following morning and see where it is. This will allow you to see where you are at with 1 quart and where your at when it's full. Either way that's my idea, it's tedious and perhaps ridiculous, but it could technically work.
Old Apr 7, 2013 | 06:13 PM
Kyle Barbaro's Avatar
how much oil would it be if my mark was down 6mm? I suck at math.. It appears im going down by 6mm every 1000 miles. Im not sure how much to add.. if I dont get any advice im gunna end up getting oil changes every 1000 miles im an under the hood noob...
Old Apr 8, 2013 | 09:44 AM
bakwoods's Avatar
I wouldn't go that far lol.
https://g35driver.com/forums/tsb-tec...ption-tsb.html
There's a whole thread about this. The 8mm TSB is interesting, however I doubt your car is doing much more than burning a normal amount of oil. Do you drive the car hard?
The way I've narrowed it down, and I'm sure someone else has thought of this is the exhaust cams have been retarded in order to increase power at redline. Problem is that the overpressurized chamber can cause blow by and to make matters worse put a strain on your PCV which in turn results in oil jumping into your intake, feeding into air/fuel and causes you to burn oil. People running catch cans probably wonder why they have oil in they're catch cans building up.
If it's that much of a worry take it to the stealership and have them do the oil change an inquire about the TSB and just explain that you noticed "an unusual consumption in oil" which to them means running the diagnostics and checking it out and recording the results. At that point if the engine is faulty you got a free motor compliments of them, if not then you've got nothing to worry about and should only have to pay for the oil change.
Old Apr 8, 2013 | 11:04 AM
I dont drive my car hard, I baby it pretty much.. I bought it off a private dealer about 3 months ago so there is no warranty due to me being at 95k so complaining wouldnt get me anywhere due to lemon laws in MA. Im okay with it consuming oil at a normal rate if you say that this is okay, I just need to know how much to refill it with if my oil level is 6mm below what it should be at my 1000 mile mark
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
