suspension /:
Old Apr 8, 2013 | 09:51 PM
alex3alex3alex3's Avatar
Question suspension /:
ok so i am planning on getting lowering springs and to adjust my camber i need adjustable upper control (a arms) and rear adjustable camber arms and do i need rear toe arms???
Old Apr 8, 2013 | 09:56 PM
EL-EE-ES's Avatar
it depends how low you go...some people are able to get back into specs with out camber arms or toe bolts. im lowered 1.5 all around and needed the arms and toe bolt to bring me back to oem specs
what set-up are you looking into?
Old Apr 8, 2013 | 10:17 PM
to be honest im not completely sure yet, i want springs that will lower me a good 1.5 to 2 inches......
Old Apr 8, 2013 | 10:24 PM
OBsessed's Avatar
You do not need rear toe arms. Toe arms will only work if you go with a true rear coilover. You may want toe bolts but there is no arm available if you're still using oem style springs. SPL makes a toe adjustable bucket but its expensive and just the bolts will suffice. You wont know with certainty if you need them until you get oman alignment rack so you may as well have them handy.
Old Apr 8, 2013 | 10:28 PM
dofu's Avatar
20 Year Member
You do want toe bolts, but you do not need toe arms.
Old Apr 8, 2013 | 10:52 PM
OBsessed's Avatar
For clarification purposes the front toe is almost infinitely adjustable as well, you'll have no problems there.
For a 1-2" drop you should also be fine without messing with rear camber, but it wouldn't hurt you to get the adjustable camber arms. I usually see the SPC rear camber arms being sold with the toe bolts as a kit from most vendors so that solves both problems.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
