Creak Noise
Old Jun 16, 2013 | 11:02 PM
  #31
sjsharky4's Avatar
Originally Posted by youloze
Good luck!
Not the brake shims man.... Took it to a mechanic, they had no clue. Any other ideas?
Old Jun 18, 2013 | 02:36 PM
  #32
totemg35's Avatar
When was the last time you took your wheel off? maybe a cracked/broken lug stud? iffy problem there.
yeah just watched again, maybe not! that's a weird rattle click.
Old Jul 2, 2013 | 12:57 AM
  #33
sjsharky4's Avatar
My wheels are constantly on an off, I don't believe I have a broken lug. I did take it to a mechanic though and he said it could be my drivetrain. I am not sure though as I have never heard of these cars having issues with their drivetrains. So im going to do the axle click diy and see what happens.
Old Jul 2, 2013 | 02:38 PM
  #34
Marlin84's Avatar
When I heard my axle click shortly after picking my G up a few years ago, it was a single click when changing from D to R, and vice versa. Like someone else said, the noise was comparable to what you hear when you have a rock stuck in a tire and you're slowly rolling through a parking lot and hear "click......click.....click", except that it's a single time. Your click is multiples, and sounds like something shaking or rattling from a shock, and slowly dissipating quickly. The more I listen through the video using my ear buds, the more it sounds like something being put under tension.. like leaning against a solid object that's deflecting against your weight. If it creaks, it could either be noise of it's own composition straining against the deflection/bending, or it could be from it slipping against another surface as it deflects..
Is the sound fairly pronounced in the cabin with windows rolled up? Or is it more muted in those conditions?
Old Jul 9, 2013 | 03:37 AM
  #35
gmonster's Avatar
My passenger window won't roll up unless I slam door and hold up passenger window button up at the same time.as long as I keep the window somewhat up it works fine till I roll it all the way down then it gets stuck. Any ideas what's causing this?
Old Jul 15, 2013 | 11:08 PM
  #36
sjsharky4's Avatar
Alright, I finally solved the problem. Turned out to be the axle click. Thank you to everyone that helped and or gave me input. This case is closed.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
