What is this on the side of the car? Pics attached.
Jan 30, 2005 | 05:54 PM
Just got a 2005 5AT coupe and noticed some clear protector material in front of the rear tire on the side molding (see pics)
Is this supposed to be here or did someone in detailing forget to take off some of the plastic protective tape? It actually doesn't look too bad, but I don't think it was meant to stay...wonder if it would protect the rear side from paint chipping.
Can someone who just got a coupe see if you have it on your car? Thanks
What is this on the side of the car? Pics attached.-rearwall1.jpg   What is this on the side of the car? Pics attached.-rearwall2.jpg
Reply 0
Jan 30, 2005 | 05:58 PM
It's equivalent protective film like that used in the clear bras. Don't try to remove it. It's applied in that postion where the body flares out a bit and has a tendency to catch road debris etc. It will save you from potential rock chips.
Enjoy the ride.
Reply 0
Jan 30, 2005 | 06:16 PM
As RBull said, it's a clearbra type protector from rocks hitting the panel.
You should wax that protector as you would the rest of your car.
Reply 0
Jan 30, 2005 | 07:06 PM
thanks for the replies guys.
wow, i was just about to remove them because i thought for sure that they were supposed to come off.
so every coupe has these from the factory? i guess they do look like they were put on for a reason...
Reply 0
Jan 30, 2005 | 07:08 PM
Yes, they're on every Coupe from the factory. They're not clear like a clear bra, they're body colored, but it does the same job.
Reply 0
Jan 31, 2005 | 11:55 AM
Quote: Yes, they're on every Coupe from the factory. They're not clear like a clear bra, they're body colored, but it does the same job.
why do you say they are body colored? i pulled mine off and mine were certainly clear as they should be. i hated them there. dirt would always get stuck along the edges and it would make them very noticable. i dont mind the clear bras on front but not there on the sides.
Reply 0
Jan 31, 2005 | 11:57 AM
I took mine off too....PITA
And mine is CLEAR!
Reply 0
Jan 31, 2005 | 12:20 PM
wow, I never knew about that portion being protected from factory. Absolutely no idea.
Reply 0
Jan 31, 2005 | 12:21 PM
i left mine on. it's there for a reason, protection. i've never had dirt buildup either.
Reply 0
Jan 31, 2005 | 12:39 PM
mines is starting to build up dirt in the corner... I don't know how since I rarely drive my car...
Reply 0
Jan 31, 2005 | 12:43 PM
Quote: why do you say they are body colored? i pulled mine off and mine were certainly clear as they should be. i hated them there. dirt would always get stuck along the edges and it would make them very noticable. i dont mind the clear bras on front but not there on the sides.
The guy who installed my clear bra told me they were body colored. I've since told others this info, that's probably where the above comment came from.
Reply 0
Jan 31, 2005 | 01:38 PM
Quote: The guy who installed my clear bra told me they were body colored. I've since told others this info, that's probably where the above comment came from.
i also have it on the '05 coupe i picked up last friday. thought the car was scratched when i first saw it. mine also look like they are painted... unless it's some optical illusion . the line is more noticable on mine with all the salt build-up this passed weekend. i have a black car.
Reply 0
Jan 31, 2005 | 01:52 PM
As far as I know, they always come with that. I asked the dealer guy and thats what he told me
Reply 0
Jan 31, 2005 | 01:53 PM
you all have to be kidding. you bought a car without knowing that something was installed on it? did anyone actually look over the car and ask questions, or just walk up and buy something?
100% not body colored clear 3M bra from factory... Mercedes and Porsche are now jumping on the same trend, clear bra is a huge paint-life saver.
Reply 0
Jan 31, 2005 | 02:25 PM
hmmmmm... too bad they don't do the front bumper like that
Reply 0
