Cel Phone Holder for the G
As I have my 6MT now, I realize I cant put my phone in the ash tray under the radio since it interferes with throws. Also the Razo, wont the weight of the phone and the holder cause the air vents to tilt down or wear more quickly??
I am still on my search for a phone holder heh..
any other suggestions??
I would suggest a blue tooth kit. I have the Sony Ericsson HCB-30 (maybe they have newer models by now?) and I like it very much. You get in the car, turn on your keys, and your cellphone is hooked into the system without you ever touching it. One side benefit of having the bluetooth kit is once in a while I forget to take my cellphone with me and the kit emits a different tone when it doesn't detect a cellphone on start up, which reminds me to go back inside to get my phone.
I believe mine was just under $200. You can check around the web to see what's available and how much they cost. But a couple of hundred dollars is reasonable.
Here's where I mounted my control panel, microphone, & speaker. I didn't try to hide wires too much but they give you more than enough length if you want to run them almost anywhere. I also just used the speaker that came with the kit, which is actually plenty loud. If you know what you're doing you can hook it into your car's speaker system and listen to the phone through that. (or just find an installer to do it if you can swing it)
Control panel
Microphone
Speaker (I just have it hanging in this location, not bolted anywhere. I have it facing up these days and it works just fine.)
Control panel
Microphone
06g35
Feb 14, 2022 05:59 AM
