Why would engine seize with only 75k miles?
Old Jun 4, 2013 | 05:25 PM
Kyle Barbaro's Avatar
Originally Posted by saywat?
^or blinker fluid
true i didnt even think of that. when in doubt, take your clear corners out
Old Jun 4, 2013 | 05:26 PM
saywat?'s Avatar
btw parts can be purchased here
http://kalecoauto.com/
Old Jun 4, 2013 | 06:31 PM
TemjinX2's Avatar
hitting vtec too many times...but seriously poor maintence due to user incompetence.
Old Jun 4, 2013 | 06:32 PM
rsingerG35's Avatar
Did you take it to Jiffy Lube?
Old Jun 4, 2013 | 10:26 PM
livinglegend's Avatar
Love that site. very informative. OP must have already installed the "engine oil bypass kit"
Old Jun 4, 2013 | 11:47 PM
Knightstiq's Avatar
Prolly a muffler bearing. I went with sealed, no lube required
Old Jun 4, 2013 | 11:52 PM
CCG35's Avatar
My most recent oil change was at infiniti on 5-21-2013. this past saturday 6-1-2013, the engine died while driving at 230pm in afternoon, there was no rain, was about to turn into neighborhood. heard a snap then a clunk clunk, steering stiffened, was able to get car off the road. I had it towed to nissan. Car sat saturday night till monday morning. Nissan came back and said the engine is seized up. It wont crank forward or back with breaker bar. determined new engine is needed. Called infiniti consumer affairs. They said bring it to infiniti for diagnosis. Had car towed 2nd time to infiniti. Drove up 2nd day and Infiniti stated rod inside engine broke and shot out the block and created massive hole in drivers side engine block. The hole us bout big as your hand. Infiniti consumer affairs, came back today and said cannot help at all.
Every oil change was documented through Infiniti dealer or Nissan dealer. They have all the records too. Also radiator flush, tran flush, drive belts, 2 4w alignments, brand new pirellis, new brake pads, front rotors turned, rears de glazed, every oil change documented. Car was garage kept. 2006, G35 AT with only 75k miles.
Could wrong type of oil cause this or possibly not enough oil?
Infiniti told me it was lack of lubrication or redlining in an AT.
Ideas?
Attached Thumbnails Why would engine seize with only 75k miles?-6-5-2013.jpg
Old Jun 5, 2013 | 12:06 AM
Knightstiq's Avatar
I just had knee surgery, but that looks more painful.
Old Jun 5, 2013 | 12:43 AM
gary c's Avatar
With any piston driven engine this is the result of oil starvation. Crank bearing ran out of oil and seized the rod sending the piston thru the engine block, not an uncommon occurrence. Check our Marketplace for a vendors selling new long blocks if you intend to keep your G35!
Gary
Old Jun 5, 2013 | 12:51 AM
1) how often were the oil changes?
2) what type of oil was used?
3) did you ever check the oil level between changes?
the revup engines are NOTORIOUS for drinking oil, and frequently running the oil low (even if the oil is changed every 3-5k miles) can result in permanent bearing damage over time. Most likely what happened here. My guess is either one of the rod or main bearings finally said f*ck it and decided to spin or seize. Did the dealership ever mention anything to you about oil consumption, low oil level, or anything along those lines while doing any of the regular oil changes?
Old Jun 5, 2013 | 12:54 AM
rsingerG35's Avatar
He has a non revup.
Old Jun 5, 2013 | 12:56 AM
Originally Posted by rsingerG35
He has a non revup.
Pretty sure 06' is the beginning of the revup package, no? split year situation?
Edit: Didn't catch he was 5at
Old Jun 5, 2013 | 12:58 AM
rsingerG35's Avatar
He has the 5AT. Only 6MT had revup engine.
Ionic's Avatar
He has an AT
Old Jun 5, 2013 | 01:00 AM
  #30
yea I just noticed that. ha.
regardless, sounds like oil starvation
