Grinding noise on cold start up from engine ?
Old Jun 29, 2013 | 02:26 AM
  #31
jutn35's Avatar
G35 Coupe
im letting my car sit for 2 days, i tried taking a video but i couldnt hear it as pronounced as the video above. I hear it better when inside the cabin.
Old Jun 29, 2013 | 11:10 AM
  #32
JKL1031's Avatar
Its undesirable but the duration is so short to warrant work orworry.
Old Aug 20, 2013 | 05:32 PM
  #33
OhDamniiiTsRey's Avatar
Originally Posted by jutn35
UPDATE
i called my friend who works down at Tustin Infiniti and he said that its most likely the chain rattling and this is caused by low oil levels in the engine. I remember i did my oil change and it was about a quart low which is a first for me. He told me to change it every 3500 miles , ive been doing it at 4500. But im going to have him take a stethoscope to see if thats the problem about the CVT sprocket. He also said its a common problem with the 1st Gen G35s to have this rattle / grinding noise on cold starts.
You are right?! I ran the noise after each shift thinking it was gonna go away, eventually I hit the breaks hard one time and the oil light blinked for a second. I was like... WTF just happened? I hit the breaks again on purpose and it did it again! So I'm thinking im low on oil, took it in and had an oil change... The winding noise DISAPPEARED?!
When I had my civic ek hatchback back in the days, oil was so used up an old that it eventually lost its viscosity and was like water. At the time, it did make a ticking noise similar to the wind up on the G upon cold shifts. So now I know to add/change oil exactly every 3,000 miles, so either you keep track or hear the howling/winding noise as a sign of low oil.
Old Aug 20, 2013 | 06:03 PM
  #34
Ejgold55's Avatar
Low oil does all kinds of crazy things to the engine. When i first got my G with 70K miles, I had a "not good" sound in each gear after i put my first 4100 miles on the car and an oil change fixed it. CEL came on, the low oil light didn't. I invested in a floor jack and an oil catch pan and change it every 3K or less and it has never happened again. The G is not a budget minded car, nor should it be.
Old Aug 20, 2013 | 07:14 PM
  #35
joedaddy1's Avatar
why not check and top off every 1k~2k miles??
should be cheaper and ideal?
Old Aug 20, 2013 | 07:54 PM
  #36
ckendG35's Avatar
Cold Start-Up
I have a 2004 G coupe MT6 and same thing happens to me, only sometimes, split seconds on cold startup. Checked oil and was good. Will this harm engine long term
Old Aug 21, 2013 | 12:44 AM
  #37
joedaddy1's Avatar
mine has been doing it for about 8 years now. no issues
Old Aug 21, 2013 | 09:32 AM
  #38
JKL1031's Avatar
Welcome to owning a VQ. Alot of engines will tick on cold start.
Old Nov 21, 2013 | 10:55 AM
  #39
Shawno72's Avatar
Good to know
Old Jan 17, 2014 | 05:10 AM
  #40
jasminerobert's Avatar
Check the starter mounting bolts for tightness. This is the most common reason for grinding noise.
Old Mar 4, 2014 | 11:26 AM
  #41
staticwhippinit's Avatar
some people are saying its a 1000 dollar repair and some are saying that its not a problem at all and happens with VQ engines. Should I be worried or not?
I just got a synthetic oil change and 1 day later I get the rattling noise on cold starts only. It goes away once I drive around a bit and the car is fully warmed up. Did the mechanic mess something up doing the oil change?
Old Mar 4, 2014 | 11:37 AM
  #42
LoSt180's Avatar
Double check fluid levels, if okay, then sound is normal. Use regular oil next time. Cold start rattle is due to the short lag for the timing chain tensioner to build up oil pressure.
Old Mar 4, 2014 | 11:47 AM
  #43
Thanks!
I read that it can harm the engine to switch back to regular from synthetic?
Old Mar 4, 2014 | 11:49 AM
  #44
LoSt180's Avatar
Thanks!
LOL, no.
Old Mar 4, 2014 | 12:06 PM
  #45
My engine oil level looks good. So I don't have to change the tensioner? It would won't mess up the engine to leave it I hope.
