how to fix - door bottom whether seal pealing???
Old Jul 19, 2013 | 01:09 AM
MidNightG's Avatar
Anyone else have this problem, it is happening on both doors... any advice on best way to fix it?
Thanks
Old Jul 19, 2013 | 01:11 AM
MidNightG's Avatar
Wow, i spelled weather wrong, i must be really tired, ****.
Old Jul 19, 2013 | 08:02 AM
EL-EE-ES's Avatar
Had this happen to me 2yrs ago...I just replace the whole strip, it's just held by a few plastic push pins and was like $30 from the dealer
Old Jul 19, 2013 | 06:32 PM
brian8064's Avatar
I too have this issue on one side and have been meaning to check the price for replacement. $30 isn't bad. Guess I'll have to order one.
Old Jul 19, 2013 | 07:09 PM
Edwadowad's Avatar
Anyone know what the part # is ?
Old Jul 19, 2013 | 07:45 PM
bocatrip's Avatar
If you are referring to the body colored trim at the bottom of the door, it is not that cheap, but easy to replace. I replaced once side that split and looked really bad. Once you get it off, it's a good idea to clean the bottom of the door of all the dirt that accumulated over the years. Sorry, you might be referring to the black seal at the bottom of the door that is fairly cheap to replace.
Old Jul 20, 2013 | 12:43 AM
MidNightG's Avatar
I am referring to the body colored trim at the bottom of the door. If you have a part number that would be helpful.
I realize that i could buy the part but if anyone has a good solution to patching it back up for a "longer term" temporary solution that is what i am ultimately looking for.
Old Jul 20, 2013 | 01:06 AM
ckendG35's Avatar
Post
I had this problem on the driver side door. I used some JB Weld marine epoxy resin and hardener which is good against weathering. Mixed the required epoxy and laced on some heavy duty clear packing tape. Then placed the strip tape with the epoxy from the inside of the door panel. Make sure you align the torn strip to the epoxy tape and press firmly for about 1 minute. Looks like new from inner and outer of door panel....
Old Jul 20, 2013 | 07:40 AM
neo_anderson302's Avatar
This is a common issue. Buy a new at the dealer for like $30-$60 a piece or you can just remove it. I need two myself
Old Jul 20, 2013 | 08:08 AM
EL-EE-ES's Avatar
here you go....easy to find the part with the use of google
http://www.InfinitiPartsUSA.com/Item...984-119096.htm
Old Jul 20, 2013 | 11:38 AM
MidNightG's Avatar
perfect, thanks ckend. Im gonna give that a try!
Old Jul 21, 2013 | 12:27 AM
bchalks's Avatar
I just cut mine off...
Old Jul 22, 2013 | 02:28 AM
MidNightG's Avatar
if my attempt at fixing it is unsuccessful that may be my option as well
Old Jul 23, 2013 | 09:56 PM
vipjd39's Avatar
ive done this pretty easily. what im battling now is the weather stripping on the windonws.
Old Aug 6, 2013 | 04:49 PM
06G35c6mt's Avatar
I just checked for this part at a dealer a week or so back, over $100.00 (2006 G Coupe) it's a bottom door seal. got the PN from Infiniti and found it online much cheaper.
