weird noise in the axle area
Old Jul 23, 2013 | 12:48 PM
Malcolm Rojas's Avatar
so i heard this is a common problem on the g there is a weird noise in my rear axle, i took it to the infiniti dealership, and they said my rear axle is dry, is that really it, and would it really be fixed if i just opened it up and lubed it.
Old Jul 23, 2013 | 12:52 PM
LoSt180's Avatar
Search for "axle click"
Yes the fix is applying lube to the splines in the rear hub. There's some how to's floating around.
Old Jul 23, 2013 | 12:54 PM
thanks ill do that
Old Jul 23, 2013 | 06:05 PM
gary c's Avatar
What you're hearing is axle clicking. You're aware there's no reason to have the Infiniti fix this issue? Nissan is less expensive and if you can locate a Nissan trained independent mechanic the saving would be even greater!
Gary
Old Jul 23, 2013 | 07:14 PM
Eno's Avatar
Eno
I had it too and depending on your coverage (and the dealership) I had mine covered by my drivetrain warranty. I agree with Gary on the Infiniti vs. Nissan thing too.
If you're at ALL a car guy with some tools you could do it yourself as well- as mentioned above the DIY is very easy to follow and with minimal tools and about 2 hours (probably less if you know what you're doing) you could probably have it buttoned up.
The expensive part, if I recall, is the particular grease that is recommended... can be VERY expensive to get the EXACT stuff recommended- though some have offered alternatives in various threads.
Once fixed, however, that clicking is gone- so no fear... it's not a money pit issue.
magnetism80
Feb 1, 2019 10:00 AM
reaper76
Sep 20, 2015 11:59 AM
Albanian122
Sep 12, 2015 04:02 PM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
