6MT will not rev past 2.5k, just replaced Camshaft sensor Bank 2
Old Sep 23, 2013 | 09:13 PM
ChrisKG35's Avatar
Okay so I had a SES light on with the code P0345... It called for a Camshaft position sensor replacement so i went ahead and replaced it today. I did an ECU reset and the car started but with a hardstart like before. I drove it around and no SES light went off but I cant rev past 2500 rpm or the car will flutter almost like it will stall... same thing in Neutral. I need help please!!!
Old Sep 23, 2013 | 09:16 PM
Eno's Avatar
Eno
Sounds like safe mode- not sure about why if you did a reset. Hope someone else can contribute.
Old Sep 23, 2013 | 09:34 PM
ChrisKG35's Avatar
Yea im confused, also I don't know why I am having a hard start problem too -.- my starter will eventually go bad haha
Old Sep 23, 2013 | 09:52 PM
JaE35's Avatar
Moderator
G35 Sedan
Where'd you get the sensor from and is it OEM? Sounds like a problem with that sensor
Old Sep 24, 2013 | 08:34 AM
J0hnblaze's Avatar
U replaced the drivers side or passenger side?!
Old Sep 24, 2013 | 09:55 AM
ChrisKG35's Avatar
I got the sensor from advanced auto parts, I can't recall the brand so I don't believe it was OEM. I replaced Bank 2, drivers side. Code was p0345
Old Sep 24, 2013 | 12:02 PM
HotRodG35's Avatar
Try cleaning the MAF sensor.
Old Sep 24, 2013 | 09:29 PM
ChrisKG35's Avatar
What do you recommend cleaning it with? I use dust off but idk if i should do more... Also I started it again today and it would rev fine but then SES came on with the same code... p0345 WTF!! Im saving my $80 and returning it pronto lmfao. Also when I reset the code I could rev fine again but the the SES would come back and BOOM same problem... Help please!!
Old Sep 25, 2013 | 05:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
Use CRC MAF cleaner, works like a charm.
Old Sep 26, 2013 | 09:04 AM
ChrisKG35's Avatar
Okay so I returned the sensor and bought some of that CRC MAF cleaner and sprayed it on my sensor's and their connectors (hopefully it doesn't do harm, im thinking it wont). When that and the original sensor was done, the car still hard started but I could rev normally without going into limp mode like it would after one rev. I haven't drove it around so I dont know if the code will come back. Hopefully not
Old Sep 28, 2013 | 03:14 PM
ChrisKG35's Avatar
Sprayed the MAF and the sensors and their connectors with the cleaner and put everything back. Code is gone drove around for 45 mins and it never came back. Now only thing I'm confused about is why it's still hard to start. Could it be my battery?
Old Sep 29, 2013 | 10:54 AM
ChrisKG35's Avatar
Bumpity bump bump
Old May 1, 2014 | 03:40 PM
G35sil's Avatar
Ever figured it out?
Old May 1, 2014 | 04:03 PM
ChrisKG35's Avatar
Yup it was a combination of a bad fuel pump the crank sensor ! Buy the whole assembly because just buying a pump and rigging doesnt give a tight enough seal for the nozzle.
Old May 1, 2014 | 04:12 PM
G35sil's Avatar
Dam im having the same issue but if i unplug my cam sensor bank 2 the car runs fine just takes a while to start. If i plug the cam sensor in, the car wont go past 2500 rpm. Throws 2 codes only, p0345 and p0328 which i already replaced the the crank sensor, bank 2 cam sensor, and knock sensor. Dam g35
