Questions about window motor and regulator
Old Oct 17, 2013 | 08:16 PM
hkjai's Avatar
Hi everyone. So my passenger side window stopped working so I did a fair amount of searching through the forum and I believe it's the common bad window motor. I came across a thread where somebody said that even if the motor is bad the window would still go down/up when the door is open/close. My question is that could it be a window regulator problem as well since my window doesn't go down/up when I open/close the door. Thanks for your time.
Old Oct 17, 2013 | 08:22 PM
JOKER's Avatar
CLUB MODERATOR
If motor bad, window never goes up or down.
Search the forum, there are threads on how to fix those motors. It's not that hard
Sometimes all that you need is a clean and possibly new brushes. Quick fix that will save you $100.
Old Oct 17, 2013 | 08:33 PM
hkjai's Avatar
Thank you for clearing it up. I already tried cleaning it and still no response so I guess I would need a new motor.
Old Oct 17, 2013 | 09:24 PM
kpowe1's Avatar
Yes, it could be the regulator. Im going through the same problem with my passenger side window also. The only way to be sure is to get in there. I just order me a new regulator Tuesday so I feel your pain.
Old Oct 17, 2013 | 09:26 PM
JOKER's Avatar
CLUB MODERATOR
https://g35driver.com/forums/interio...or-repair.html
Old Oct 17, 2013 | 09:36 PM
hkjai's Avatar
So you got a new regulator instead of a new motor?
Old Oct 17, 2013 | 09:38 PM
hkjai's Avatar
Do you know the signs for a bad regulator? I looked around and couldn't help anything helpful.
Old Oct 17, 2013 | 09:43 PM
kpowe1's Avatar
What was it doing before it stop working, mine was making a loud poping sound at the end of the cycle.
Old Oct 17, 2013 | 09:50 PM
hkjai's Avatar
It closes normal, but when I roll it down it makes some kind of clunking sound. The window did come alive for a day or two then died again. That's why I'm leaning more toward a bad motor.
Old Oct 17, 2013 | 10:03 PM
kpowe1's Avatar
Either or man but a bad motor shouldn't make a clunking sound you really will have to get in there and check things out.
Old Oct 17, 2013 | 10:27 PM
hkjai's Avatar
Yeah will do it once the new motor comes in. Let me know how yours turn out. Good luck man.
Old Oct 17, 2013 | 10:30 PM
kpowe1's Avatar
Same to you
Old Oct 17, 2013 | 11:13 PM
Auungbong's Avatar
Same problem
My driver side window doesn't go up all the way not sure how to fix it. I think it's a motor problem. Any way to do it yourself? My dad told me that the way it is set up to have to take it to a shop? Any advice? I currently am overseas in Okinawa Japan and am looking to get my car fixed before I sell it and that is one of the few problems with the vehicle. The car is in CT. Maybe someone from here can fix it or assist in fixing it for a decent price? I won't be back in America until aug 2015. Thanks
- auggie
Old Oct 22, 2013 | 11:52 PM
brazen's Avatar
Try this motor reset before anything else:
http://infinitihelp.com/diy/gcoupe/p..._procedure.php
Old Oct 23, 2013 | 12:28 PM
aintnun G's Avatar
When i hold the switch to close my windows they open up again with out me pushing down on the switch, the window goes down partially and when i open the window all the way sometimes it dosent want to come up again nd i just got a new motor , does anybody know bout this problem or should i just reset the motor???
Thanks
