tranny wont go into reverse... please help
well a few weeks ago i noticed that my car was having a little bit of delay in going into reverse. right away i checked the fluid and it was full..... it seems when the car is cold it will go right into reverse but as soon as the car has been running for 10 min the car dont wanna go in to reverse. all forward gears work great still no problem just reverse.... any ideas guys my car just turned 80 k.
Cut a hole in the floor board and add a hinge. Then put the car in neutral and just fred flinstone it backwards. Once you have it out of your driveway, head straight to a mechanic.
Seriously though, it could be alot of things. Only way to find out is take it to a mechanic and have him find out. Could be an electrical grimlin in your wiring harness, could be your shift linkage, could be low pressure in your system from line blockage, pump failure, or bad seal, could be a synchro failure, and more.
It could be something as simple as a bolt is loose in your shift linkage, or you might need a new transmission. Really only a certified mechanic will be able to tell you which.
well ive been looking around and i just put my car up for the winter so im looking for some opinions...... i love my car... more then prolly any other car i have owned. the only thing i wish was different was the fact i wish it was a stick.... now that i am in to position where i have to make a decision on what to do about mine.... im throwing around the possibility of swapping to a stick.... i no theres alot to be done and im sure its not cheep but just trying to put my feelers out there has anyone ever made this swap? am i dumb for even thinking about doing it? let me no guys....need some words from the pros on this one..
Don't do the swap for the mere financial stance....you can pick up an OEM 6MT for what it would cost to swap your car. It is very doable and can be done, but your G will never be the same as a factory 6MT....trans, pedals, engine wiring harness, clutch, flywheel, gauges, etc,etc, the parts list goes on for days and 100 new things will pop up while your doing it, not mention your have to pull out airbags, the dash, interior........ I watched this project be done to a TL and it was a NIGHTMARE
tow it to a trans shop...could just be an expensive repair which outweighs a new/used car cost
seagrasser
May 3, 2022 09:43 AM
DRG35R
Sep 16, 2015 05:33 AM
