Technical weight question
Old Feb 5, 2005 | 11:01 AM
spdrcr's Avatar
I know this is on the inside of the door panel, but There are three different weights.
What is the empty weight of the '05 G35 Sport coupe? I have some paper work that I have to send out and need this weight.
Thanks
Old Feb 5, 2005 | 12:12 PM
spdrcr's Avatar
bump.......
Old Feb 5, 2005 | 12:20 PM
EverythingG35's Avatar
Well, it's going to vary depending on your options, fluid levels, etc...
It should be somewhere around 3500lbs.
However, I wouldn't be suprised if it actually weighed in at anywhere from 3400-3600+lbs
Old Feb 5, 2005 | 12:39 PM
spdrcr's Avatar
I know the curb weight is 3500lbs, but isn't the empty weight different?
Old Feb 5, 2005 | 01:05 PM
Empty as in no fluids, etc..? or empty as in no passengers? If you mean the later, then not really.
Old Feb 5, 2005 | 01:18 PM
spdrcr's Avatar
I'm not real sure. I was under the impression that they were different weights. I guess I'll just put the curb weight.
Old Feb 5, 2005 | 02:37 PM
XCELR8's Avatar
Heres the door sticker off a G coupe from Ebay. Shows the complete vehicle weight, then the front/rear weight
Old Feb 5, 2005 | 02:46 PM
XCELR8's Avatar
and another coupe from ebay. This ones from an 04 auto prem pack car. depends on the options and version coupe you have
Old Feb 5, 2005 | 02:57 PM
spdrcr's Avatar
Thanks
Old Feb 5, 2005 | 03:11 PM
SaltiDawg's Avatar
The apparently removed the twenty-five pound monkey when they measured the front/rear weights.
Old Feb 5, 2005 | 03:18 PM
XCELR8's Avatar
Yeah vehicle weights are a goofy thing. Sort of a gray area.
Old Feb 5, 2005 | 04:00 PM
CKwik's Avatar
The Gross Vehicle Weight Rating(GVWR) imprintend on the sticker is NOT the weight of your car. It is the maximum weight rating. The sticker provides both the max rating overall, and the max rating on each axle.
Old Feb 5, 2005 | 04:56 PM
RBull's Avatar
Rated M
Gvwr
Absolutley correct.
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
