Frustrating unsolvable issue
Old Nov 11, 2013 | 11:39 PM
Wandson's Avatar
Haven't been able to solve this one yet- stumps me. Tried greasing it up to no avail. I attached a link to a video of a sound my car makes. It's coming from the front area around the left suspension. Anyone ever heard annoying like this? Video is High Quality. http://youtu.be/jyhlOtCR_Io
Old Nov 12, 2013 | 11:55 AM
G35fromPA's Avatar
Have you tried spraying the a-arm and LCA bushings with lithium grease? What about the sway bar end links?
Old Nov 13, 2013 | 11:09 AM
sal210's Avatar
+1^. Thats worked for me on all my maximas. Give it a shot
Old Nov 13, 2013 | 07:07 PM
Valcrist's Avatar
Omg that's terrible!
It sounds like your dog is playing with a squeak you in the back ground!
Start with greasing bushings, but it sounds like a damn ford explorer or anything else ford pulling in and up a hill, so I'd say ball joints.
Old Nov 13, 2013 | 07:14 PM
Golden_Shower's Avatar
Check all of your bushings, sounds like you have a worn bushing somewhere
Old Nov 14, 2013 | 07:48 PM
gary c's Avatar
You need to find out why your suspension is making noise, spray and grease won't stop the noise if you have defective/worn parts. Forget the "Stealerships" find a independent brake/alignment shop in your area, they should be able to find the cause within minutes. I have 3 shops like that in my neighborhood. Good Luck & Enjoy the Ride!
Gary
Old Nov 15, 2013 | 05:18 AM
rsingerG35's Avatar
I was thinking strut mounts.
Old Nov 15, 2013 | 04:32 PM
Ejgold55's Avatar
raise the volume on your radio
Old Nov 18, 2013 | 11:03 AM
Stillen06coupe's Avatar
That little bit of pressure shouldn't make that much noise. I think it's something far more serious than a bushing. Something is not attached right or very loose. Take it to a shop. Some places won't charge you if it's a quick diagnosis. ..... Does it act funny when driving? It looks like there's a lot of movement where the tie rod attaches to the suspension. I'd check the bolts in that area to make sure they're tight
Old Nov 18, 2013 | 11:12 AM
jsmith29's Avatar
Gary
This.
You don't wanna ride around on worn suspension parts, that will only make the whole thing go faster which will cost you $$$$ and possibly an accident should it begin to affect roadworthiness.
Old Nov 22, 2013 | 09:08 AM
infinitidude's Avatar
Sounds like the lower ball joint
Old Jun 12, 2014 | 12:10 AM
Wandson's Avatar
UPDATE: I went through the winter with the squeak and it mostly stopped (or at least got quieter because i didn't hear it at all) Now the summer is coming back and so is the dry weather- I can hear the squeak sometimes again lol Car is still in one piece though. Might just take it to the dealer- Someone said bad motor mounts- but on a car with 62k? idk... I hate this sound...
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
